3 Home Signal (similar to Vodafone Sure Signal) Not working
- 3 Home Signal (similar to Vodafone Sure Signal) No...
15-02-2015 9:30 AM
I have been trying to set up my 3 home signal femtocell 3g signal booster without much success.
My Vodafone suresignal works OK with my full network setup.
I have tried my current network setup,(lots of networked devices) with the plusnet firewall https://portal.plus.net/my.html?action=firewall set to off, low (disconnect between settings)
I have also tried another setup with just an adsl router and the 3 homesignal attached.
The settings 3 support have asked my to verify
1) MTU = 1500 (checked OK)
2) All ports not blocked (plusnet end) (I need support to answer this)
3) No firewall (plusnet end) (plusnet firewall= off)
Has anybody got the 3 Home signal working on plusnet?
If so what special settings (if any) did they have to use.
Thanks in advance
Ian
Re: 3 Home Signal (similar to Vodafone Sure Signal) Not working
15-02-2015 1:01 PM
However, range indoors is very limited and speed is much slower than you get over mobile network.
It's really only handy for the numerous times mast fails and you are still indoors. Outdoors of course it's a useless black box.
There is a 3 helpline just for the Home Signal and believe it or not, they seem to know what they are talking about.
I'd recommend doing the full reset and starting again, no need to fiddle with anything in router.
15-02-2015 5:22 PM
16-02-2015 8:29 AM
Quote There is a 3 helpline just for the Home Signal and believe it or not, they seem to know what they are talking about.
Well, the first homesignal I recieved there was no sign of life, no lights or anything ; got my voltmeter out ant the power adapter was dead.....still took 45 mins for the support rep. to action a replacement.
The second phonecall (with a fast flashing green light) that was 60 mins of reseting etc.
Quote Ask "3" what (range of) ports their device uses.
At the end of that phone call they mentioned firewalls,MTU and no blocked ports......I did indeed already ask what ports in particular, but I did not receive a satisfactory reply....just something along the lines "No ports blocked by your ISP"
I will phone again and see if another rep. is more forthcoming.
Ian
16-02-2015 10:32 AM
http://www.three.co.uk/Discover/Three_inTouch
I find it works very well, it may put you on while you're trying to get the home signal working.
16-02-2015 2:47 PM
Quote "3 in touch" phone app?
Yes installed that on day 1, it is OK but the battery on my phone takes a large hit as it is struggling to keep a 3g connection up and sms messages and call history now can be seen in two separate non syncing apps.
Phoned 3 support again, and they have escalated it their end, so hopefully they will come back with more assistance.
26-02-2015 5:33 PM
I even tried on my neighbours BT connection.
The only thing I can think of is my pings of about 45ms, perhaps I will try fast path.
Ian
26-02-2015 9:53 PM
03-04-2015 9:04 AM
Still not got this working.
3 support require
1) MTU = 1500 (tick)
2) The following ports open
UDP 53
UDP 123
UDP 500
UDP 4500
TCP 80
TCP 443
I have tried
i) Forwarded these ports to the homesignal device
ii) Putting the device in a DMZ
@CRT any assistance with this
Ian
