2wire 2700hgv reset ppp question
maximod
Does resetting the ppp connection (reset isp connection) re sync the line or not ?
Paul.
Fixes: 6
Re: 2wire 2700hgv reset ppp question
No, it will get you on a different gateway but will not resync the xDSL connection.
198kHz
All Star
Fixes: 10
Wot npr said. ^^^
If you watch the router lights, you'll see that the 'internet' light goes red, then back to green, but the 'broadband' light stays green during the reset process.
Remember you are unique - just like everyone else
maximod
Thanks for the clarification.
Earlier today i disconnected the router, and after reconnecting the broadband is sluggish.
As the sync is good but the evening snrm is 4+ db, i want to  hop gateway without re sync, hence the question.
Paul.
