2wire 2700hgv reset ppp question
- Re: 2wire 2700hgv reset ppp question
27-02-2013 7:59 PM
Does resetting the ppp connection (reset isp connection) re sync the line or not ?
Paul.
Paul.
Message 1 of 4
(915 Views)
3 REPLIES 3
27-02-2013 8:02 PM
No, it will get you on a different gateway but will not resync the xDSL connection.
Message 2 of 4
(553 Views)
27-02-2013 8:14 PM
Wot npr said. ^^^
If you watch the router lights, you'll see that the 'internet' light goes red, then back to green, but the 'broadband' light stays green during the reset process.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 3 of 4
(553 Views)
27-02-2013 9:42 PM
Thanks for the clarification.
Earlier today i disconnected the router, and after reconnecting the broadband is sluggish.
As the sync is good but the evening snrm is 4+ db, i want to hop gateway without re sync, hence the question.
Paul.
Paul.
Message 4 of 4
(553 Views)
