2MBPS only against 15 MPBS indicative
- 2MBPS only against 15 MPBS indicative
21-02-2015 11:49 AM
I just moved over to Plusnet ADSL and dumped BT fibre. Its been over 15 days and the speed has settled to a mind boggling, super duper 2.1 MBPS
Can any geniuses here tell me if it is worth calling PlusNet at all? or should i buy a decent router off the shelf? suggestions plz
Message 1 of 3
(664 Views)
2 REPLIES 2
Re: 2MBPS only against 15 MPBS indicative
21-02-2015 11:59 AM
Please provide the information requested here http://community.plus.net/forum/index.php/topic,96155.0.html
Also is the speed 2.1 megabytes per second (MBps) or 2.1 megabits per second (Mbps)
If the former that may not be too bad
Message 2 of 3
(457 Views)
21-02-2015 12:11 PM
Your line is looking nice and stable
Is your router plugged into the master socket without any extension leads being in use?
The loop loss is suggesting your line is pretty long, which goes against the estimates somewhat.
Up Down
Loop Loss: 38.3 60.5
SNR Margin: 6.5 2.5
Speed: 715 3047
Message 3 of 3
(457 Views)
