2704n router faulty?
- 2704n router faulty?
- « Previous
- 1
- 2
- Next »
Re: 2704n router faulty?
08-06-2015 8:58 PM
Join the club And I note no-one has managed to say it so far, welcome to the forum.
Message 16 of 22
(423 Views)
08-06-2015 9:01 PM
Quote from: jotojotopo Does anyone know if we use an off-the-shelf router to connect to Plusnet?
Sorry, only just spotted that nobody has answered this for you, the answer is yes, but on ADSL you need a modem/router of course
Welcome to the forum as well.
Message 17 of 22
(423 Views)
08-06-2015 9:03 PM
Quote from: ticktak Same for me too. Joined Friday, and having the same problems as others have reported.
Are you still having a problem or has it been resolved?
Welcome as well.
Message 18 of 22
(423 Views)
09-06-2015 11:31 AM
Thanks Anotherone for checking if I'm now okay. I think I am, but it's early days as I thought I had sorted a couple of times before. What seems to have worked for me, is to do a factory reset via the web browser rather than the pin in the back of the router.
Thanks again.
Thanks again.
Message 19 of 22
(423 Views)
09-06-2015 5:51 PM
Thanks for that information ticktak, interesting. Out of curiosity had you tried the pin in the back factory reset previously?
Message 20 of 22
(423 Views)
09-06-2015 8:16 PM
Yes, I tried the pin about three times over a couple of days and found it worked for a few minutes only. I then tried your suggestion of the pin, unplugging etc, but that also failed for me. In desperation I went into the router settings and did a factory reset, which has now worked for over a day, so I'm hoping it's all sorted.
Cheers.
Cheers.
Message 21 of 22
(423 Views)
09-06-2015 8:20 PM
Great stuff. When I have a chance, hopefully later this week, I shall have a play with a few things. I'll post here if anything interesting comes to light.
Message 22 of 22
(423 Views)
- « Previous
- 1
- 2
- Next »
