2704N Router fault
cosmic_jester
2704N Router fault
Hi, new customer here having issues with the above router.
Internet connection is fine (if very slow) however when I call up the routers IP (192.168.1.254), I can see the current settings but if I click any of the buttons (to change the password etc)  it tells me the page cant be displayed. (See image)
What I have done so far:
turned the router off and on again.
done a factory reset using the button on the router.
If anyone can suggest a solution (other than getting a new router) I would be very grateful.
Cheers
Dave
Tags (1)
1 REPLY
bill888
Seasoned Pro
Fixes: 22
Re: 2704N Router fault
What web browser are you using?
If it is Safari, try using chrome.
