2704N Router fault
- 2704N Router fault
2704N Router fault
22-09-2016 9:56 PM
Hi, new customer here having issues with the above router.
Internet connection is fine (if very slow) however when I call up the routers IP (192.168.1.254), I can see the current settings but if I click any of the buttons (to change the password etc) it tells me the page cant be displayed. (See image)
What I have done so far:
turned the router off and on again.
done a factory reset using the button on the router.
If anyone can suggest a solution (other than getting a new router) I would be very grateful.
Cheers
Dave
Message 1 of 2
(476 Views)
1 REPLY 1
Re: 2704N Router fault
23-09-2016 10:27 AM
What web browser are you using?
If it is Safari, try using chrome.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Message 2 of 2
(441 Views)
