21cn roll out hold up?
watledge
Hi
Does anyone know if there is a problem with the 21cn roll out as when I checked my exchange on samknowsbb last year it was scheduled for upgrade in Q1 2010 - when I check now it says nothing at all.
I also heard a rumour of problems with the system causing a hold on new updated exchanges.
Nick
Fixes: 103
Re: 21cn roll out hold up?
Hi Nick,
My exchange is in a similar boat Sad
Wholesale have recently announced a list of exchanges to be done later this year but mine isn't on it meaning there's no longer an RFS date.
The situation might be the same for you unfortunately. If you're exchange isn't in this list then you're out of luck for the time being!
http://community.plus.net/21cn-exchange-availability/
pierre_pierre
what does the term open mean on that list, is it job done?, My funny Rx - close to exchange went from 12 yesterday to 8.5 now, still got the same synch of 8128
Fixes: 71
Since the list is for ISPs (primarily) I think open means that it's enabled and ISPs can place orders to switch customers onto it (as in 'open for business').
David
