21CN no speed increase - investigation result
- 21CN no speed increase - investigation result
21-10-2009 1:25 PM
"Thanks for the update, further tests are still showing errors which though your SNR has reduced from 15 its more than likely whats stopping your sync rate from going any higher, unfortunately this rate is still way above your BT assigned fault threshold rate so they wont accept a fault on this however it may be worth trying a few tweaks at your side such as changing the filter, trying alternate hardware if you have access to borrow some etc
Should you require any further testing please let us know.
Kind regards"
Since I've already tried alternating hardware at my end I can only assume that there's nothing I can do to remove these errors since there's not enough of them to be classed as a 'fault' that BT will look at.
Does this mean that ADSL2+ is more twitchy with regard to errors? If so should BT be looking to change their definition of 'acceptable' errors in preparation for the new technology?
I guess I'll just have to live with the 3.2MBits I'm currently getting until something happens to the local infrastucture by default
Re: 21CN no speed increase - investigation result
21-10-2009 1:57 PM
Quote Does this mean that ADSL2+ is more twitchy with regard to errors? If so should BT be looking to change their definition of 'acceptable' errors in preparation for the new technology?
Quite possibly! We've been talking with BT about that and I know a number of other ISPs have also been doing so.
21-10-2009 3:20 PM
on fastpath my 50ddb atten line seems to be ok with around 250 ES in 24hours anything over that and the DLM must start to get worried.
20cn dlm use to allow my ES on faspath to sumtimes clock up a 1000 ES in 24 hours during a thunderstorm and not batter an eye lid.
250es or 1000es it dosent seem to degrade my traffic or exprince of the web at all
22-10-2009 1:36 PM
Quote from: Jameseh
You could use me as a test case to prove your point. Get BT to completely clear up my line in the interests of 'science' and then compare the results
24-10-2009 11:23 AM
It ain't gonna happen, though, is it?
Graham
24-10-2009 12:41 PM
SW.
3Mb FTTC
25-10-2009 5:18 PM
I guess we'll all just have to wait for the government to come good on its promise to provide fiber optics to local nodes by 2012 or whatever they're gassing about these days. It's pledged that every home should have at least 2MBits by then.
Considering that South Korea has it's sights set on 1000MBit connections by 2012 our infrastructure seems woefully inadequate for the task.
25-10-2009 5:55 PM
25-10-2009 6:58 PM
25-10-2009 10:17 PM
Quote from: ASBO @ complex. you will find in most the places that have huge bandwidth over fibre given to them at affodable prices are countrys that have very little rules on what can be strung on telegraph poles. if it was allowed in this country am sure even bt would have had the country fibered up by now but the fact is they have to go under ground which takes time and alot of money. esp for FTTH
I appreciate the reasons but it doesn't change the situation. If our self imposed (or EU?) rules mean we need to spend 10 times as much as other countries then I guess we're screwed for the short term yes?
25-10-2009 10:43 PM
http://community.plus.net/forum/index.php/topic,80277.msg653375.html#msg653375
Theres a bug on that router.
Ive bein having a tinker with one this wkend and when it happens its straight after a resync. i did force a g.992.1 sync and it didnt happen.
26-10-2009 11:35 AM
Uptime: 4 days, 18:21:35
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 3,335
Data Transferred (Sent/Received) [MB/MB] 12.94 / 254.67
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 27.0 / 47.0
SN Margin (Up/Down) [dB]: 17.5 / 9.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 1,545
HEC Errors (Up/Down): 0 / 798
ASBO - Do you think those erroneous errors could be finding their way back to the exchange? I ask because I'm still seeing no speed increase on ADSL2 and can't figure out why. If the exchange thinks anyone with a 585 is actually experiencing billions of errors it could account for the seemingly locked speeds, right?
26-10-2009 12:38 PM
i reckon on my line running my trusty dg834 v4 if the DLM sees over 500 heading towards a 1000 ES an CRC in a 24 hour period it starts messing about with bands and snr changes. i currently run at a average of 250 ES an CRC aday but when a thunderstorm hits it can soon clock the ES up
@complex or penfold. if you find your selfs up at midnite over the next few days, could you check what your ping times are like on 21cn. i want to see if this problem http://community.plus.net/forum/index.php/topic,80166.0.html is just on the chesterfield exchange or not.
26-10-2009 12:53 PM
26-10-2009 1:05 PM
how long have you bein on the
in your very first reply there is abit about PN replying to a ticket regarding the high errors.
Quote Thanks for the update, further tests are still showing errors which though your SNR has reduced from 15 its more than likely whats stopping your sync rate from going any higher, unfortunately this rate is still way above your BT assigned fault threshold rate so they wont accept a fault on this however it may be worth trying a few tweaks at your side such as changing the filter, trying alternate hardware if you have access to borrow some etc
was this what they could see on the stats they can pull up on your line or had you given them the error rates the thomson router was reporting
