21CN much earlier than expected
jelv
Fixes: 10
Re: 21CN much earlier than expected
Yes, or it may get picked up from here in the morning by one of the Plusnet team.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
oldskooldaze
Ok looking at everything above is way over my head  Grin
Can somebody please decipher  and more importantly do i need to alter anything Wink
Some stats
Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a fixed line speed up to 2Mbps.
Our test also indicates that your line currently supports an estimated ADSL Max broadband line speed of 8Mbps; typically the line speed would range between 7Mbps and 8Mbps.
Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 17Mbps; typically the line speed would range between 15.5Mbps and 19Mbps
Our test also indicates that your line could support an estimated ADSL 2+ Annex-M broadband upstream line speed of 1Mbps and downstream line speed of 17Mbps; typically the downstream speed would range between 15.5Mbps and 19Mbps.
Uptime: 19 days, 21:25:28
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 445 / 19.843
Data Transferred (Sent/Received) [GB/MB]: 1,99 / 531,83
Output Power (Up/Down) [dBm]: 10,5 / 0,0
Line Attenuation (Up/Down) [dB]: 11,1 / 19,5
SN Margin (Up/Down) [dB]: 30,9 / 2,6
Loss of Framing (Local/Remote): 26 / 0
Loss of Signal (Local/Remote): 10 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 34.440 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 43 / 24.840
HEC Errors (Up/Down): 19 / 195.367
jelv
Fixes: 10
@oldskooldaze
Your in a very similar state to IanSn, everything looks great, you just need to ask for your upstream to be uncapped which will roughly double your upstream speed.
adamwalker
Fixes: 221
@oldskooldaze
Give me a shout if you want me to raise an order to uncap the upstream for you.
 Adam Walker
BRABUS
x47c - I don't mind if your figures are wrong.  If my speed increases at all then I am happy.  If your figures are remotely close then I will be over the moon Smiley
oldskooldaze
Quote from: _Adam_Walker_
@oldskooldaze
What does this involve, are there any costs ?
BRABUS
Just raise a ticket or hope Adam sees your reply.
They just tweak some setting at their end and you get a faster upload speed, it either happens the same or next day.  There is ZERO cost involved in doing this so you have nothing to lose.
chrispurvey
@oldskooldaze
There is no cost to uncap your upstream. Would you like me to place the order for you?
oldskooldaze
Please Chris
Thanks Phil
dick:quote
chrispurvey
That's been placed for you now and will take one working day to complete.
If there's anything else then give me a shout.
Chris
