21CN is there anything I need to do?
- 21CN is there anything I need to do?
Re: 21CN is there anything I need to do?
03-01-2012 10:42 PM
03-01-2012 10:47 PM
04-01-2012 8:04 AM
Modem Status
Connection Status Connected
Us Rate (Kbps) 883
Ds Rate (Kbps) 15025
US Margin 12
DS Margin 14
Trained Modulation ADSL2Plus
LOS Errors 0
DS Line Attenuation 3
US Line Attenuation 0
Peak Cell Rate 2082 cells per sec
CRC Rx Fast 0
CRC Tx Fast 0
CRC Rx Interleaved 0
CRC Tx Interleaved 32
Path Mode Fast Path
That's a good start, now onwards and upwards! lol
04-01-2012 9:09 AM
04-01-2012 12:14 PM
04-01-2012 10:09 PM
"You can help the testing process by rebooting your router (switch it off and on again) three or four times over the first 10 days. You'll get better results if you can do this in the morning."
I take it this is no longer applicable?
04-01-2012 11:21 PM
It's very unpredictable what a reboot will do - Dynamic Line Management has a mind of its own sometimes (as you have been seeing).
05-01-2012 8:18 PM
Quote from: fatdeeman three or four times over the first 10 days
That's three or four times in total over the first 10 days (not 3 or 4 times a day for the first 10 days).
06-01-2012 5:59 PM
06-01-2012 6:55 PM
06-01-2012 7:04 PM
All I know is the exchange is something like 150-200 meters away, I can actually see the building from my front window it's that close! I know the wiring doesn't always take a direct route but I think it's safe to say I'm close.
The downstream margin has always been around 14 and I've always had pretty close to top whack speeds prior to the exchange being upgraded.
06-01-2012 10:15 PM
Have you had a high margin since you saw the 15K sync on 21CN?
06-01-2012 11:39 PM
09-01-2012 2:07 PM
I wonder if the router is to blame, I don't think adsl2+ was even available anywhere back when I bought it so perhaps it's just a chipset limitation.
09-01-2012 5:20 PM
I've changed your profile to 13200 to allow for your BT IP profile. Having ran a line check I see your SNR is 14dB, which is quite high for such a short line. If you want me to look into this I would need you to plug into the test socket so I could run some more checks.
Jojo
