21CN figures - a couple of weeks in
PhyllisTyne
Connection seems fairly solid and speed tests consistent around 11.5/1.1. sometimes seems on go slow for a couple of seconds.
What do these figures look like to some of you experts out there?
Uptime: 9 days, 7:51:15
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,268 / 13,497
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 13.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 16.5 / 28.5
SN Margin (Up/Down) [dB]: 6.0 / 5.5
Loss of Framing (Local/Remote): 32 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 67 / 0
FEC Errors (Up/Down): 0 / 9,471,689
CRC Errors (Up/Down): 0 / 13,761
HEC Errors (Up/Down): 0 / 12,552
PT
1 REPLY
Fixes: 52
Re: 21CN figures - a couple of weeks in
The stats look OK to me. Sync speeds/bandwidth reasonable for the attenuation; average time between CRC errors is about 60 seconds which is satisfactory.
David
