21CN WBC enabled now (I think), probably need a new router
ErraticWorm
Exchange was due for an upgrade. It may have happened this morning (looking at my stats). My Billion 7800N broke so I am back on my Linksys WAG54GS (v.1 I think); I don't think this router is ADSL2 compatible.
The Billion had a much higher attenuation (+5) than the WAG but also had a very marginally better dl; as all I ever read is higher attenuation is worse it is a little confusing.
Sooooo the question is, which router should I look at next?
Opinions if you care to share!
I'm not interested in the Thompson thank you!!!
[edit]
I can't attach my line stats as an acceptable type right now. ADSL2 framing is mentioned which wasn't there last time I looked. My D SNR is lower than usual- usually around 9.
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime  Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 364
8 Kbps
Link Power State: L0
Mode:                  G.DMT
Channel:                Interleave
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):      5.8            18.0
Attn(dB):      58.5            31.5
Pwr(dBm):      18.6            12.3
Max(Kbps):      3936            996
Rate (Kbps):    3648            448
                        G.dmt framing
K:              115(0)          15
R:              16              16
S:              2              8
D:              16              4
                        ADSL2 framing
MSGc:          1              1
B:              94              15
M:              2              8
T:              1              1
R:              16              16
S:              2.1684          9.0000
L:              760            128
D:              16              4
                        Counters
SF:            406387          406385
SFErr:          87              0
RS:            13817178                3454272
RSCorr:        5281            0
RSUnCorr:      854            0
HEC:            81              0
OCD:            1              0
LCD:            0              0
Total Cells:    59439894                0
Data Cells:    3507671        0
Drop Cells:    32
Bit Errors:    0              0
ES:            897            0
SES:            1              0
UAS:            27              0
Total time = 1 days 19 hours 28 min 55 sec
SF  = 80374686
CRC = 2096
LOS = 0
LOF = 0
ES  = 897
Latest 1 day time = 19 hours 28 min 55 sec
SF  = 4124515
CRC = 120
LOS = 0
LOF = 0
ES  = 66
Latest 15 minutes time = 13 min 55 sec
SF  = 49108
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 15 min 0 sec
SF  = 52989
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 1 day time = 24 hours 0 sec
SF  = 5082321
CRC = 270
LOS = 0
LOF = 0
ES  = 120
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 52930
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 52931
CRC = 82
LOS = 0
LOF = 0
ES  = 37
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 52930
CRC = 3
LOS = 0
LOF = 0
ES  = 2
Fixes: 62
Re: 21CN WBC enabled now (I think), probably need a new router
With that reported attenuation you will be on ADSL1 as is shown by the router stats so unless you really want to buy a new router I wouldn't bother as you are most unlikely to see any improvement
Note that for your attenuation your speeds are very good
ErraticWorm
Disappointing but not entirely unexpected.
