21CN WBC - SRA?
- 21CN WBC - SRA?
21CN WBC - SRA?
06-05-2010 4:49 PM
Cor. What an acronym-ridden topic title.
So - my exchange is 21CN enabled, and I've got a router (Billion BiPac 7402nx which is SRA-capable) which can facilitate this. Is this something I should enable? What benefit will I get from this?
Still getting my teeth into ADSL.. apologies for the stream of semi-n00b posts!
Cheers folks.
Cheers folks.
Message 1 of 2
(896 Views)
1 REPLY 1
Re: 21CN WBC - SRA?
06-05-2010 4:59 PM
At the moment 21CN does not support SRA, BT have turned it off for some reason only they understand.
There is a rumour they are may change this and are going to trial SRA at some time in the future. Maybe Mr. T will be along and update us on this subject.
3Mb FTTC
3Mb FTTC
Message 2 of 2
(343 Views)
