21CN RFS date set
- 21CN RFS date set
21CN RFS date set
17-07-2012 11:42 AM
A friend has had his exchange RFS date for 21CN set to the end of the month, does he have to do anything to get ADSL2+ , at the moment only gets 0.5MB should he see an improvement?
Message 1 of 3
(1,213 Views)
2 REPLIES 2
Re: 21CN RFS date set
17-07-2012 12:17 PM
If it's the last date of the month it may be a place-holder and not a definite date.
When this says it's available your friend can either wait for the bulk upgrade or request an upgrade here.
This is the sort of thing you should be looking for...
Have a look at this chart in conjunction with your friend's router stats.
Quote Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 13Mbps; typically the line speed would range between 7.5Mbps and 17.5Mbps.
Message 2 of 3
(445 Views)
17-07-2012 1:14 PM
Unless for some strange reason he's on a fixed 512 connection, he's not going to see much (if any) improvement.
Can you find out what his router says for the downstream attenuation?
Message 3 of 3
(445 Views)
