*21CN ONLY* Do you think your PN profile is not updating as it should?
- *21CN ONLY* Do you think your PN profile is not up...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
06-03-2012 12:03 PM
06-03-2012 1:33 PM
It was incorrectly raised to 4500 in question 52239019 (that was my sync rate at the time, not ip profile)
It should be set to 4000 now by my calculations (my current sync is a little over 4600)
06-03-2012 1:50 PM
11-03-2012 9:00 PM
Many thanks,
Rob
12-03-2012 9:08 AM
12-03-2012 9:33 AM
Thanks to all your hard work, have had a stable line over the weekend, with BT IP profile holding at 5.91 for a few days now, but Plusnet IP profile yet to catch up from yesterday's update to 5.1 from 4Mb where it had been stuck since sign-up. Maybe later today? Keith.
12-03-2012 4:57 PM
I have raised your profile to 12300 to allow for your new BT IP profile. This should take effect shortly.
Jojo
12-03-2012 4:58 PM
I'll look into that and post back here.
Jojo
12-03-2012 4:59 PM
Your profile is already set at 5100.
Jojo
12-03-2012 5:28 PM
[Moderator's note by Jim (Oldjim) a lot of blank lines removed ]
12-03-2012 10:42 PM
Would you mind taking a look at my line. Was switched over to 21CN but my line speed is the same as my 20CN speed. There was a problem when I was switched over and for a few days I lost internet connection but my sync was 7.5 - 8mb down and 1.1mb upload. Maybe I'm still on ADSL 1?
Current stats
4764 kbps download
445 kbps upload
Noise Margin 12db
Attenuation 43db
13-03-2012 12:31 AM
Quote from: Joanne They have identified the issue and are initiating a fix for it. Sadly, it's not a simple one and will take a number of weeks to implement. I'll update here when we get an idea as to when it will be resolved.
Quote from: Joanne I'll see if I can find out any more today.
The Antarctic day must be nearly over, any news yet?
13-03-2012 9:39 AM
Jojo
13-03-2012 12:10 PM
Quote from: Nokk Hi Jojo
Current stats
4764 kbps download
445 kbps upload
Noise Margin 12db
Attenuation 43db
Hi Jojo
Are you able to look into the above for me pls. Thansk Nokk (Nokoni)
13-03-2012 4:36 PM
|Your target SNR is currently 15dB so that won't be helping. How is your connection set up. Are you using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
