*21CN ONLY* Do you think your PN profile is not updating as it should?
- *21CN ONLY* Do you think your PN profile is not up...
Re: *21CN ONLY* Do you think your PN profile is not updating as it should?
13-01-2012 11:48 PM
I'm connected at 9637, BT speed tester says my profile is 8263 and PN Member Centre says Current line speed: 11 Mb, though it may be down to me being on the IPV6 trial. The 582n does synch at 11Mb but I'm using my Cisco because of lots of line drops.
14-01-2012 2:28 PM
14-01-2012 6:56 PM
[Moderator's note by Adie (dvorak): Full quote of preceding post removed, as per Forum Rules ]
15-01-2012 3:03 PM
Router stats:
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,140 / 12,052
Bandwidth (Up/Down) [kbps/kbps]: 443 / 12,184
Data Transferred (Sent/Received) [MB/MB]: 4.58 / 46.30
Output Power (Up/Down) [dBm]: 12.0 / 20.0
Line Attenuation (Up/Down) [dB]: 8.0 / 21.0
SN Margin (Up/Down) [dB]: 28.0 / 12.0
(my username is gj8090 )
16-01-2012 12:09 AM
16-01-2012 2:34 PM
Quote from: goldenadsl My router had been sync at 18676K, with BT IP at 16477K for few days now and PN IP still at 13.6 Mb
not from what I can see
Jojo
16-01-2012 2:46 PM
Quote from: 32110 My PN profile is still being reported as 10.1MB but several speedtesters, including PN and BT, are showing download speeds in excess of 11M. My current sync is 13376
I have raised your profile to 11700 to allow for your new BT IP profile. This should take effect shortly.
Quote from: 32110 is the PN profile updating OK but not the report showing in the Member Centre/Connection Settings/High-speed Broadband tab?
No, I've checked the BT system where the report is and the new profile is not showing there either.
Jojo
16-01-2012 2:48 PM
Plusnet Current line speed still showing at its previous value of 6.6Mbps at 16/01/2012 14:45, approaching 2 days delay.
David
16-01-2012 2:49 PM
16-01-2012 3:04 PM
I've also nudged that up for you.
Jojo
16-01-2012 4:19 PM
David
16-01-2012 4:24 PM
16-01-2012 5:22 PM
16-01-2012 11:00 PM
Quote from: Joanne Thanks gavin11,
I've used yours as an example but I've also answered your query here.
Jojo
Perfect, now getting speedtests in excess of 10Mb and iPlayer HD is working perfectly.. thanks Jojo !
17-01-2012 11:43 AM
