21CN Migration
machare
21CN Migration
Is there a a guide to the Plusnet procedures for 21CN Migration? - bearing in mind that at the moment my line is connected at a down speed of 1600 Kbps.
Samknows shows my exchange, Seal, NDSEA as having 21CN WBC RFS date as  31st March, but the Plusnet user tools say: "BT have advised that no current planned date for WBC on 21CN exists."  Which is right?
Michael Chare
10 REPLIES 10
niko
Re: 21CN Migration
sam knows seems better
i would guess at that speed you would be given the advice to go onto adsl1 but on the 21cn system
jelv
Fixes: 10
Re: 21CN Migration
I have to take a strong drink whenever I find the Plusnet information is up to date! SamKnows will be right.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Strat
Fixes: 565
Re: 21CN Migration
This has been recently updated https://www.btwholesale.com/shared/document/Library/Network_Information/21CN_Broadband_Availibility/...
jojopillo
Re: 21CN Migration
Hi machare,
I'd pop your number in the BT Availability Checker, it's only when it's in there can we place orders for it.
Jojo Smiley
machare
Re: 21CN Migration
Well that says:
"Our test also indicates that your line currently supports an estimated ADSL2+ broadband line speed of 1Mbps; typically the line speed would range between 1Mbps and 3.5Mbps.
The actual stable line speed supportable will be determined during the first 10 days of use. This speed may change over time, to ensure line stability is maintained."
The spreadsheet says 21CN is due between 1st and 31st March.
dick:quote
hitachi
Re: 21CN Migration
I think if the availability checker gives an adsl2+ speed then it is already available.
Strat
Fixes: 565
Re: 21CN Migration
Unless it also says "Your exchange is planned to have ADSL2+ by *date in the future*" as mine does.
machare
Re: 21CN Migration
Well it does not say that. But BT Retail say that ADSL2+ is not available.
dick:quote
jelv
Fixes: 10
Re: 21CN Migration
Did you do the lookup using your phone number or using the postcode?
machare
Re: 21CN Migration
Quote from: jelv
Phone number.
