21CN Enabled Exchange
mojorisin
Hi All
Just noticed that my Exchange is showing as 21CN WBC status:Enabled on Sam Knows and also the BT checker says that i could get ADSL2+
Currently on ADSL Max
Question is how do i go about getting this upgraded ? Do Plusnet do it automatically ?
thanks in advance
mojo
Fixes: 78
Re: 21CN Enabled Exchange
I've just raised order 1-10204011340 for you which is due to complete and upgrade your line to 21CN on the 29th. Smiley
Adam
 Adam Walker
mojorisin
Hi Adam
Many thanks for that just got an email to say it had failed automatically but a manual request has been made and should be done by the 19th Dec
Do i need to do anything when the change takes place ?
cheers
Mick
Fixes: 78
No you shouldn't need to do anything on the 19th.
 Adam Walker
mojorisin
Is there anyway to tell If I have been moved yet ?
jojopillo
Hi mojorisin,
I've just looked into your order and it says that it's not due for completion until the 30th. I can only presume there was some delay with the provisioning.
Jojo Smiley
mojorisin
Ok thanks for checking  Smiley
mojorisin
Hi
i have now been migrated to the 21CN had a couple of router drops and my profile speed has dropped to 1.25mb is it possible to give it a manual boost to get it back to normal please ?
Fixes: 78
I've just updated the profile on your account so you should see some improvement now.
 Adam Walker
mojorisin
Many thanks  Smiley
