21CN ADSL2+
col5
21CN ADSL2+
Can anyone tell me if these settings on my router are right for 21CN ADSL2+
Encapsulation: RFC 2364 PPPoA
DSL Modulation Mode: MultiMode
Multiplexing: VC
QoS: UBR
PCR Rate:
SCR Rate:
Autodetect: Disable
VPI: 0
VCI: 38
Enable: 1
PVC Status: Up
1 REPLY
CX
Re: 21CN ADSL2+
MultiMode should negotiate the highest possible standard, which will be ADSL2+ if you're on 21CN (unless your line has been specifically configured otherwise by BT, e.g. for stability purposes). On most modems/router you can check what was negotiated once you are connected.
21CN will work with either PPPoA or PPPoE.
