21:00 - time to forget about boroadband?
- 21:00 - time to forget about boroadband?
22-03-2014 9:43 PM
For the past two nights it's been impossible to stream anything at certain times.. Without wishing to descend into the dark arts, my download varies between 0.78 - 1.65, but only after about 21:00. During the day and early evening there are no problems, so I don't think it can be anything at "my end" (technical term).
Is anyone else having the same issue?
Message 1 of 4
(846 Views)
3 REPLIES 3
Re: 21:00 - time to forget about boroadband?
22-03-2014 10:28 PM
You are not alone!
Just read through all 27 pages of this.
http://community.plus.net/forum/index.php/topic,124744.0.html
Message 2 of 4
(491 Views)
22-03-2014 10:43 PM
Crikey! (it's the best I could do)
I'm surprised that it's so widespread - you may have noticed that my technical knowledge in this area is "challenged", but if you're paying for a service that only does what it should do when you don't usually need to use it, it approaches useless.
Unfortunately I've just tied into a 12 month contract, so my only option is to scream and scream until I'm sick. If I can't stream anything after 21:00, it defeats my object of choosing "unlimited".
Message 3 of 4
(491 Views)
24-03-2014 9:42 AM
Hi Spacie,
I disagree, I'd raise a fault at http://faults.plus.net so we can look into the possibility that this might be more of an individual problem affecting your connection.
Quote so my only option is to scream and scream until I'm sick
Message 4 of 4
(491 Views)
