20 mb/s speed drop
- 20 mb/s speed drop
Re: 20 mb/s speed drop
19-05-2014 12:43 PM
PPP drops shouldn't cause any adverse affects to DLM, they don't that much on ADSL to be honest. We see them as PPP drops but most drops due to a fault are caused by the line erroring, making the line unstable and causing a retrain, which causes the PPP session to drop.
My advice is always to try and keep the PPP session active for as long as possible, however, I understand this isn't always possible, especially in situations such as these. The problem with ADSL is that the Router carries sync and PPP sessions so it's a little more tricky trying to get the point across to drop the PPP session as opposed to just switching the router off.
19-05-2014 12:52 PM
Urban myth then... So (when you have time) why has there been so much / frequent advice to do manual session drops?
Kevin
19-05-2014 12:55 PM
My belief is that it's an urban myth.
One thing that annoys me is Plusnet's reliance on the visual radius graph. Gateway hopping looks like a line drop on the graph and a brief loss of sync which does not lose PPP doesn't show. We've had a case very recently where Plusnet said the line was stable but sync was dropping very frequently.
19-05-2014 12:57 PM
19-05-2014 1:16 PM
It's not something that everyone in the relevant departments do unfortunately, but I'm looking at ways we can make that possible. It's not as easy as giving people to right tools, they need to know how to use them and need to know what they are looking for.
31-05-2014 7:19 PM
31-05-2014 7:29 PM
31-05-2014 7:33 PM
31-05-2014 9:14 PM
10-06-2014 9:45 PM
1. Product name: BT Home Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 15:51:59
6. Data rate: 15000 / 32400
7. Maximum data rate: 22161 / 85871
8. Noise margin: 9.6 / 19.0
9. Line attenuation: 0.0 / 17.6
10. Signal attenuation: 0.0 / 17.6
11-06-2014 11:16 AM
I think there's a problem with your line. It looks as though there's a jointing issue on the copper part of the network. Could you raise a fault at http://faults.plus.net so we can get that sorted out for you?
11-06-2014 12:13 PM
2. Serial number:
5. VDSL uptime: 1 days, 06:32:18
7. Maximum data rate: 21805 / 85480
8. Noise margin: 9.1 / 18.9
11-06-2014 12:57 PM
11-06-2014 1:01 PM
11-06-2014 7:44 PM
2. Serial number:
5. VDSL uptime: 1 days, 13:59:15
7. Maximum data rate: 22161 / 85544
8. Noise margin: 9.6 / 18.9
