20 bytes per second
- 20 bytes per second
Re: 20 bytes per second
13-01-2009 1:21 PM
Please let me know and I'll get an engineer booked for you as soon as I can.
13-01-2009 2:11 PM
New Buffalo router in place but problem persists.
Anotjer strange issue is that when i type a web address it finds it and connects but takes forever to load the page.
If i search for the site in google and click on the link it loads much faster
13-01-2009 2:28 PM
I've fired it back at BT who'll shortly pass the fault back to us to get engineer times.
One other thing - Have you tried using non-Plusnet DNS servers? Or to actually specify on the router to use ours?
13-01-2009 2:31 PM
latest speedtester result 2 kbps - I Need this fixed urgently - this has been with you since 8 pm last night and the only thing we have achieved is that i am £50 down for a new router - i have business support on this line but am not receiving it !!
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 5024 kbps(DOWN-STREAM), 832 kbps(UP-STREAM)
IP profile for your line is - 4000 kbps
Actual IP throughput achieved during the test was - 2 kbps
[Moderator's note by Jim (Oldjim) All caps removed as per forum rules ]
13-01-2009 2:33 PM
I Need this fixed today - my business is at a standstill
jim:blue All caps removed as per forum rules mod:end
13-01-2009 2:55 PM
13-01-2009 4:39 PM
As discussed on the phone, you should have an engineer between 0800-1300 tomorrow.
I'll try to give you a ring once it's done.
13-01-2009 10:54 PM
13-01-2009 11:11 PM
14-01-2009 1:38 PM
Quote from: newmillscomp I am paying PlusNet for a service which PlusNet are not providing.
My connection has degraded substancially since November and now is totally unuseable.
You are paying PlusNet for a service which they are providing, however you are unable to receive due to (what sound like) either problems with your phone line and/or exchange.
I wold also like to 'chip in' that I feel we are all very lucky to have PlusNet staff willing to spend time reading and posting on these forums, even out of their normal working hours, and this should not be taken for granted. There are far too many companys out there who don't know the true meaning of Customer Service. Touch wood, should I ever need to contact PlusNet urgently over a serious issue (such as no connection etc) I would do it by phone.
Not trying to rise to anything here, just spending my two pence worth...
J
14-01-2009 6:07 PM
Your DSL connection rate: 5088 kbps(DOWN-STREAM), 832 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 3308 kbps
14-01-2009 6:42 PM
Quote from: newmillscomp no conformation on ticket as to what the fault was though !
Now that is something that an awful lot of people would be interested to know.
You did have a very strange problem, so it will be fascinating to know the cause - and solution.
14-01-2009 8:28 PM
15-01-2009 9:35 AM
Any word back from BT as to waht the problem was ?
15-01-2009 9:39 AM
BT reported that there was a fault on the NCIF, but I'm not actually sure what that means
I'm sorry noone got back to you to see how things were going. I'd meant to last night, but then got preoccupied with a bunch of process related stuff I had to write.
If the fault had been raised via the CSC, you would have had a call back, it was because I raised the fault as a "personal issue" that it was down to me to get in touch.
