20 bytes per second
- 20 bytes per second
Re: 20 bytes per second
13-01-2009 9:14 AM
13-01-2009 9:15 AM
13-01-2009 9:17 AM
13-01-2009 9:19 AM
13-01-2009 9:24 AM
Could you escalate this as I have Business Support on this line and have 4 customer PCs here which need an internet connection.
It is now 13 hours since fault raised.
thanks
13-01-2009 9:45 AM
Can you please confirm that this is being escalated.
thanks
13-01-2009 9:47 AM
Everything that you've said (and what CSC put on the ticket on your account) points towards an exchange problem and the fact that you've said that BT were at your DP suggests that there's an issue there that they are working on.
We can't get any escalation without a fault being raised though. I'll try to get that raised in the next half hour.
13-01-2009 9:51 AM
next door are on PlusNet (a referral from me) and they are not having any problems
think i might move next door lol
13-01-2009 9:58 AM
13-01-2009 12:08 PM
13-01-2009 12:18 PM
Are the engineers still poking around? Do they look thirsty? I don't think it could hurt if you asked them what they were actually doing to see if they could answer why your connection had completely died.
Unfortunately, as your Broadband ISP, we're only able to speak to Wholesale regarding your line. Because it's voice line work, you'd need to contact your telephone supplier to find out what's going on and they will be able to speak to OpenReach.
I'm sorry that we weren't able to help more.
13-01-2009 12:26 PM
I am paying PlusNet for a service which PlusNet are not providing.
My connection has degraded substancially since November and now is totally unuseable.
BT speedtester result
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 5824 kbps(DOWN-STREAM), 832 kbps(UP-STREAM)
IP profile for your line is - 4000 kbps
Actual IP throughput achieved during the test was - 2 kbps
YES 2 kbps !!
13-01-2009 12:53 PM
13-01-2009 1:00 PM
I'm afraid Mark's not at his desk right now.
BT have replied to the fault that I raised this morning stating that they can send an engineer (a broadband one) to your premises, but if no fault is found then a charge in the region of £160 would be raised.
If BT (OpenReach) are doing work on your line currently, then this is likely to be the cause of the problem. Is this still ongoing?
13-01-2009 1:04 PM
I am plugged into the test socket (there are no extensions off the faceplate anyway)
I have tried 3 thompson 585 routers and changed the filters but the last speedtester result was 5 kbps.
I am going to argos now to buy a new router to totally eliminate the Thompson question
