17-08-2011 1:58 PM
Message 1 of 2
(456 Views)
1 REPLY 1
Re: Slower and slower
17-08-2011 5:02 PM
It's probably worth raising a fault anyway, either for dropping connection or slow speed. Your connections over the past week do show some drops in connection:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13135964798819.png" />
though if this was you powering off to resync the router then it's nothing to worry about. If they are drops then raise the fault as intermittent, otherwise a slow speed issue would be best - if you include some speed test results (ideally from the bt speed tester: http://www.speedtester.bt.com) in the comments that'll give us something further to go on.
Message 2 of 2
(226 Views)
