2 Microfilters into one telephone socket ?
ossettbob
I have just received a phone call (which is very good) from the support team. He told me that I could plug in my router later today as I am going live tomorrow. I still want to use my Talktalk system until my phone is switched over. Can I plug 2 microfilters into one telephone socket (i have 2-way telephone adaptor ) ?. That way, I can plug my talktalk old modem into one microfilter and my Plusnet router into the other.
Re: 2 Microfilters into one telephone socket ?
NO!  Crazy
ossettbob
Thanks for that. Didn`t want to mess anything up !!!
Fixes: 162
Once our service is live, it's more than likely the TalkTalk broadband won't be available to you.
 Chris Parr
 Plusnet Staff
Fixes: 62
A word of warning
Plugging a Plusnet supplied router into a TalkTalk service can allow the TalkTalk equipment in the exchange to say - look a new router but it is TR069 enabled so we will set it up for TalkTalk
This happened with a Plusnet router I loaned to a friend on TalkTalk as his router was suspect. Not only did it connect automatically but it changed the router login and password and the only way I could get access when I got it back  was to do a hard reset
ChrisL
Quote from: HPsauce
NO!  Crazy
I had a set-up like this for five years or more:  dect telephone and dial-up usb modem in one filter; printer fax and built-in soft modem in another;  filters connected to a telephone splitter/adaptor.
What problems should I have noticed, but didn't?  Cheesy
Chris
It's totally different with a dial-up modem, with DSL you connect with equipment at the exchange and only one router can be connected on a given line at a time.
Call me 'w23'
ChrisL
Makes sense ... thanks!
Devonian
I agree with Oldjim.
When I had my brief moment of service with talktalk, on migration day I was at work, when I left I was connected to PN, when I got home, I was still connected to PN... I thought, as my router was still connected.
I switched on the latop, I had an internet connection.
I checked the router stats, it said I was still connected to PN and the PN login/password were still saved to my router..
I run a speed test, and I was getting a completely different profile reported.
I was connected to talktalk, but via my router with the PlusNet settings still showing.
How and why?  No idea!!!
Fixes: 10
Because you are hard wired to SilenceSilence equipment in the exchange it connects you without using the login details?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Probably.
Call me 'w23'
