2 Days with Plusnet and wanting to leave
Fixes: 334
Re: 2 Days with Plusnet and wanting to leave
So buy one that isn't.
Longliner
All Star
Fixes: 8
@johntboyle wrote:
Do you know what I will just leave it...
That's your best suggestion yet. Good luck!
Gel
Champion
Fixes: 29
Fixes: 460
@johntboyle wrote:
Yeah, you are absolutely right…please advise me on what help?  Do you honestly think that you answered my question upgrade to a business account, use a BT hub 6…
Who said anything about a business account? I suggested buying the business version of a Smarthub from an auction site.
This was a genuine attempt to suggest a budget solution to your need for a hub with better wireless performance and the option to set the DNS server.
I get the impression that you came here to sound off rather than seek help.
pint
My take on things is that ISP supplied kit is generally [-Censored-] for want of a better word.
 Things have improved with some costlier ISPs, but plusnet are keeping the tradition of supplying [-Censored-] kit alive and well
For most people ( or some?) [-Censored-] kit thats been hobbled by firmware will just about do for the rest then something a little better is required .
 I've always seen it as Plusnet ( or any other ISP) supplies a service down the line - such as internet access and a voice service and its upto you to either go with the budget router, or get something else.
 Plusnet are not unique in this respect.
 If you did a little research into plusnets supplied routers before signing up you would find out all you need to know ( ie the router is  [-Censored-]) but the service ( apart form the router) isnt that bad
