2 Days with Plusnet and wanting to leave
- Re: 2 Days with Plusnet and wanting to leave
03-10-2021 4:26 PM
Plusnet router the worst I have had. Plusnet agreed and suggested I use a BT Hub 6....unbelievable!!!!
Decided to leave as only 2 days of service...£140 to cancel as my 14 days cooling off is when I signed the contract.
I asked before I joined any restrictions…No. So why can’t I change the DNS?
Can anyone advise on a modem or modem / Router other than the BT Hub 6?
03-10-2021 4:31 PM - edited 03-10-2021 4:32 PM
@johntboyle Depends which restrictions you questioned. What actual problems have you had/got?
The BT HH6 is a better router than the Hub1, so the suggestion was a fair one.
You haven't given Plusnet much chance to rectify any perceived problems, have you?
03-10-2021 4:40 PM
If you want to select your DNS servers then get a Business version of a Smarthub or spend more money depending on what other features you need. Pusnet is a budget provider and supply a budget hub.
03-10-2021 4:44 PM
I don't expect a provider to send a substandard product and agree, then say “oh use another modem / router”. Why would you give a company a chance, then say oh if you are a business customer wait until the 14th October and you can upgrade to get a new modem / router that you can change the DNS and is much better. I have never experienced such service, its breath taking.
03-10-2021 4:45 PM
Any restrictions...No...really?
03-10-2021 4:47 PM
Try answering my original questions, then some of us could possibly suggest solutions.
03-10-2021 4:49 PM
On my original post I said "DNS restriction"
03-10-2021 4:50 PM
Ok - see @Baldrick1 's suggestion at post #3 - and his later comments.
03-10-2021 5:09 PM - edited 03-10-2021 5:10 PM
Ok and my question is other than BT hub 6..."Can anyone advise on a modem or modem / Router other than the BT Hub 6?"
03-10-2021 5:11 PM
Depends what you want to spend, really.
03-10-2021 5:17 PM
Do you know what I will just leave it...
03-10-2021 5:19 PM
OK - if you don't want to help us help you - have it your way.
03-10-2021 5:25 PM
Plusnet does not put any restrictions on which modem/router you use, so any ADSL if you are on ADSL will do as long as it is not locked to another supplier - same applies to VDSL if you have FTTC.
03-10-2021 5:33 PM
Yeah, you are absolutely right…please advise me on what help? Do you honestly think that you answered my question upgrade to a business account, use a BT hub 6…really?
But in another sense, you have helped indirectly as this exchange has confirmed that I don’t want to be with Plusnet, and an additional reason is that if the community think that this level of service is acceptable, then I can’t accept this. It is dreadful…6 years ago I had a BT Hub 5 and it was rubbish then.
So thank you for your help with my decision.
03-10-2021 5:35 PM
The supplied Modem/Router is restricted.
