2 Days with Plusnet and wanting to leave
johntboyle
Plusnet router the worst I have had.  Plusnet agreed and suggested I use a BT Hub 6....unbelievable!!!!
Decided to leave as only 2 days of service...£140 to cancel as my 14 days cooling off is when I signed the contract.
I asked before I joined any restrictions…No.  So why can’t I change the DNS?
Can anyone advise on a modem or modem / Router other than the BT Hub 6?
19 REPLIES 19
Legend
Fixes: 254
Re: 2 Days with Plusnet and wanting to leave
@johntboyle Depends which restrictions you questioned. What actual problems have you had/got?
The BT HH6 is a better router than the Hub1, so the suggestion was a fair one.
You haven't given Plusnet much chance to rectify any perceived problems, have you?
Fixes: 418
@johntboyle
If you want to select your DNS servers then get a Business version of a Smarthub or spend more money depending on what other features you need. Pusnet is a budget provider and supply a budget hub.
johntboyle
I don't expect a provider to send a substandard product and agree, then say “oh use another modem / router”.  Why would you give a company a chance, then say oh if you are a business customer wait until the 14th October and you can upgrade to get a new modem / router that you can change the DNS and is much better.  I have never experienced such service, its breath taking.
johntboyle
Any restrictions...No...really?
Legend
Fixes: 254
Try answering my original questions, then some of us could possibly suggest solutions.
johntboyle
On my original post I said "DNS restriction"
Legend
Fixes: 254
Ok - see @Baldrick1 's suggestion at post #3 - and his later comments.
johntboyle
Ok and my question is other than BT hub 6..."Can anyone advise on a modem or modem / Router other than the BT Hub 6?"
Legend
Fixes: 254
Depends what you want to spend, really.
johntboyle
Do you know what I will just leave it...
Legend
Fixes: 254
OK - if you don't want to help us help you - have it your way.
Mustrum
Fixes: 77
Plusnet does not put any restrictions on which modem/router you use, so any ADSL if you are on ADSL will do as long as it is not locked to another supplier - same applies to VDSL if you have FTTC.
johntboyle
Yeah, you are absolutely right…please advise me on what help?  Do you honestly think that you answered my question upgrade to a business account, use a BT hub 6…really?
But in another sense, you have helped indirectly as this exchange has confirmed that I don’t want to be with Plusnet, and an additional reason is that if the community think that this level of service is acceptable, then I can’t accept this.  It is dreadful…6 years ago I had a BT Hub 5 and it was rubbish then.
So thank you for your help with my decision.
johntboyle
The supplied Modem/Router is restricted.
