1mbit speed - usually 7-8mbit
- 1mbit speed - usually 7-8mbit
12-11-2011 1:24 PM
The odd thing is that for very brief periods my speed goes way high to 10-12mbits?
Is there a problem in my area at the moment or is my router on the way out or what? Is there anything I can do?
Any help would be very appreciated.
My exchange is 1.2 miles away. Here is the info from my thomson plusnet router.
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 11,139
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 15.0 / 32.5
SN Margin (Up/Down) [dB]: 31.0 / 9.5
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 3
HEC Errors (Up/Down): 0 / 2
Re: 1mbit speed - usually 7-8mbit
12-11-2011 1:27 PM
12-11-2011 1:34 PM
12-11-2011 1:35 PM
12-11-2011 1:38 PM
FALLINGS PARK
Estimated line speed:
5Mb (This may vary between 3.5Mb and 7.5Mb) - Checked on 2011-11-04 19:56:08
Current line speed:
1 Mb
couldnt see any links so is this the info you asked for?
12-11-2011 1:46 PM
For the BT speedtest - see the sticky at the top of this board
12-11-2011 1:57 PM
i entered my phone number and it stopped on "checking details" for over a minute then:
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
chrome wasn't listed as suitable browser and i have kept IE6 for a work reason.
is there a particular browser that it will definitively work with? do i need to enter the service ID?
12-11-2011 2:00 PM
Although it is about time you updated it
12-11-2011 2:18 PM
anyway, did it with another machine with IE8 and same result.
is it working for you?
is it essential to do the speedtest with the bt one? i have tried it about 10 times now and keep getting the same response.
12-11-2011 2:44 PM
The only other thing is to phone support and ask them to check the actual IP profile.
I assume that it may have increased if you are on the updated dynamic line management system. If it has then ask them to manually change the Plusnet copy. Otherwise wait for it to happen automatically
12-11-2011 3:00 PM
i managed to get the bt test to work
Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
780 Kbps
0 Kbps 21000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 780 Kbps
For your connection, the acceptable range of speeds is 4000-21000 Kbps.
Additional Information:
Your DSL Connection Rate :10271 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 9061 Kbps
Upload Speed
358 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 358 Kbps
Upstream Rate IP profile on your line is - 443 Kbps
then i was preparing to do the next BT test so I went to go check the support phone number for plusnet just in case i got my login password wrong, but as i was doing that i noticed everything felt super quick again so i did another quick speedtest and got this
i wrote down the numbers then did another test and got this:
now i will do the BT advanced test
12-11-2011 3:12 PM
This Last Test comprises of two tests
Download Speed
7357 Kbps
0 Kbps 21000 Kbps
Download speedachieved during the test was - 7357 Kbps
Your DSL Connection Rate :10407 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 9181 Kbps
Upload Speed
363 Kbps
0 Kbps 443 Kbps
>Upload speed achieved during the test was - 363 Kbps
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the second test.
12-11-2011 3:16 PM
12-11-2011 4:07 PM
12-11-2011 4:27 PM
anyway looking at my results from BT - does it indicate a line issue or plusnet service issue?
