1G ethernet
ntownsend
1G ethernet
I've always tried to keep wired devices wired where possible, to maximise the performance of the wifi. However, even that is beginning to show signs of capacity, without too many devices on. Ideally, the modem router would support 1g ethernet on its ports - can my tg582n be configured to do this?
Fixes: 62
Re: 1G ethernet
nope - pity isn't it
ntownsend
Re: 1G ethernet
Indeed - is anyone expecting a modem from plusnet with (at least) one 1g ethernet port?
jim:quote
frank39
Re: 1G ethernet
Won't a gigabit switch, at less than £25 for an eight port (when I last bought one), do what you need?
Fixes: 10
Re: 1G ethernet
Considerably less than that for a 5 port!
http://www.ebuyer.com/225791-tenda-5-port-gigabit-switch-g1005d
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
frank39
Re: 1G ethernet
What unfortunate person has to turn those out at that price?  You could hardly buy the PSU for that - it's as bad as Primark.
davidj66
Re: 1G ethernet
And probably last as long as a Primark tee shirt Grin
Fixes: 10
Re: 1G ethernet
OK - how about one from a reputable manufacturer: http://www.ebuyer.com/411321-netgear-gs205-5-port-gigabit-ethernet-switch-gs205-100uks
Or for one in a metal case: http://www.ebuyer.com/52760-netgear-prosafe-gs105-5-port-gigabit-switch-gs105 still only £20. A warning about this one however - if you drop it it is likely to damage the floor - but the switch will be fine.
khaled35
Re: 1G ethernet
Fixes: 131
Re: 1G ethernet
Same here on the TP-Link and it just works fine.
Customer and Forum Moderator.
