198.18.1.x address problems
- 198.18.1.x address problems
Re: 198.18.1.x address problems
15-12-2014 5:49 PM
The first link makes very clear that the browser is doing its own caching - whilst I see the merit of the pre-fetch, local caching seems illogical. It leads to duplication of caching and unexpected results. The platform has already got DNS caching in the comms stack, so why duplicate it else where?
The second link goes nowhere.
Kevin
15-12-2014 8:00 PM
Very strange, the link works at this end.
15-12-2014 10:17 PM
Quote from: Townman The second link goes nowhere.
Let me rephrase that - it goes to McAfee's site but to a page which says the content cannot be found.
15-12-2014 10:23 PM
The first time I clicked on it I got the page saying you need to enable cookies and now it is page cannot be found
15-12-2014 10:28 PM
Update:
After clearing the browsers cache, re-trying the link gave me a page telling me how to enable cookies.
I've temporarily allowed third-party cookies and get the above screen capture web page again.
16-12-2014 11:52 AM
Quote from: Townman
EDIT: @CRT see post 15 here - http://www.gpforums.co.nz/threads/478377-Windows-8-1-Upgrade-Ramifications - there is a suggestion there that there is a specific issue between Win8 and TGs
See also posts here - http://answers.microsoft.com/en-us/windows/forum/windows_8-networking/internet-connection-dropping-w... - from 12 Jan 2014 onwards.
Is this on your / the CSC / Product's radar?
Sorry, not sure how I missed this thread.
I've asked the question internally if it's something we're aware of and what can be done, I'll get back when I've got a response.
16-12-2014 1:04 PM
18-12-2014 9:44 AM
Have you had an internal response please?
There is another report of the same issue here - http://community.plus.net/forum/index.php/topic,135034.new.html#new - which did not get quite the right advice from the CSC.
Again I ask the question, does the CSC know about this strange condition bringing together 3 technology failures...
1. No response from PlusNET DNS (based on observation that the problem does not occur when Win8 PC DNS is changed to Google)
2. TG582n treats DNS non-response as WAN down and delivers a spoofed IP address
3. Win8 multiple caching of IP address resolution causes confusing behaviours which makes the problem look like something else - e,g. Intermittent wifi
I suggest that an alert flash across CSC is required to avoid inappropriate, potentially expensive advice is given to customers.
A fix to the DNS response issues or the TG behaviour ought to fix this. Please send me a PM if products or networks need more input on this problem. If there are diagnostics which can be set or gathered from the TG on DNS lookups, I am quite happy to assist.
Cheers,
Kevin
18-12-2014 12:17 PM
18-12-2014 1:16 PM
Quote from: Townman I found that changing the DNS settings to use Google's DNS (8.8.8.8 and 4.4.4.4) virtually eliminated the problem,
Can you confirm that this change is being done on your Win8 machine? (and not in the TG).
I've not been following this thread for a few days so trying to do a quick catch up. I'm coming to the conclusion that this issue is possibly related to a combination of Browser DNS Pre-fetching & WANDownSpoofing.
Quote from: Townman Can you explain what this does, why it does it and the consequence of disabling it please?
As far as I can tell, and also going by npr's comment, disabling WANDownSpoofing certainly won't have a detrimental effect and may well solve the issue.
As I mentioned in reply #32 if Plusnet's DNS server responds (even with a page not found) then a Spoofed entry does not exist. If for some reason the TG thinks the DNS server hasn't responded (due to Pre-fetching?) and there is a spoofed entry this may cause some conflict.
20-12-2014 2:08 PM
Other systems on the same network, including W8.1, seem to be OK.
I started my own thread here: http://community.plus.net/forum/index.php/topic,135116.0.html but will continue here for now.
Note that I am using Microsoft Security Essentials (and IE10 mostly) on W7 and Defender on W8.1, no third-party protection.
20-12-2014 4:14 PM
http://npr.me.uk/changedns.html ; (method 2)
20-12-2014 4:18 PM
Does changing the DNS settings require a router restart (xDSL or PPP)?
20-12-2014 4:31 PM
I was thinking the issue might be related to the 582n sending each DNS query to both its DNS servers at the same time. I suppose in a way that behaviour should make things more reliable, since you should only need to get a reply from one of the two servers. But if both queries or replies get destroyed by a burst of CRC errors, or both get dropped somewhere due to congestion, there's no other DNS server address for it to fallback to after the timeout.
I thought it might be interesting to try configuring the router to use Plusnet's DNS servers, but manually assigning them different metric values, so that it would try one, and then the other if the first fails to respond. You could use the 212.159.13.49 and 212.159.13.50 IP addresses if that makes it easier to configure.
20-12-2014 4:47 PM
Quote from: Townman
No.
