198.18.1.x address problems
- Re: 198.18.1.x address problems
13-12-2014 8:51 PM
Anyone any clues on the following please...?
Multiple devices attached to same router. All work fine aside from new Wim8.1 laptop (W8L) which has started giving problems.
W8L cannot presently connect to websites. DNS resolution is fine - nslookup using local DNS / PlusNet DNS / Google DNS all return correct IP address for the requested domain. Ping to domain targets 198.18.1.x where x appears to increment for each attempted target.
All suggestion welcome please...
Kevin
13-12-2014 9:02 PM
I did wonder about moving this to Windows but let us see how it goes
13-12-2014 9:07 PM
13-12-2014 9:07 PM
Correct - Win7 (the one posting here) and the Win8 laptops are sat next to each other connected by WiFi.
Just been reviewing other threads on this subject all seem to reference DNS issues... which does not appear to be in play here.
@Purleigh - yes - basics covered - and can access the web service on this lappy BY NAME.
Kevin
13-12-2014 10:00 PM
Does your W8L firewall logs give any clue ?
13-12-2014 10:06 PM
As a test have you tried disabling windows 8.1 firewall and/or any other security/av software ?
14-12-2014 10:36 AM
C:\Users\Kevin>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Trinity
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Wireless LAN adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 24-FD-52-95-BF-42
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : 7C-05-07-A2-D5-27
Wireless LAN adapter WiFi:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Realtek RTL8188CE Wireless LAN 802.11n PC
I-E NIC
Link-local IPv6 Address . . . . . : fe80::ace4:cb7b:a147:2d77%3(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.98(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 13 December 2014 23:48:46
Lease Expires . . . . . . . . . . : 15 December 2014 10:29:06
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 254082386
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-35-1D-9F-24-FD-52-95-BF-42
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:87f:1a8e:3f57:fe9d(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::87f:1a8e:3f57:fe9d%7(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 117440512
NetBIOS over Tcpip. . . . . . . . : Disabled
C:\Users\Kevin>nslookup
Default Server: dsldevice.lan
Address: 192.168.1.254
> plus.net
Non-authoritative answer:
Addresses: 212.159.9.2
212.159.8.2
> exit
C:\Users\Kevin>ping plus.net
Pinging plus.net [198.18.1.150] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 198.18.1.150:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Turning off the McAfee firewall makes no difference. Note that the trial version of this has expired... but I cannot update it as I cannot access the internet.
14-12-2014 10:52 AM
It does sound very much like an internal DNS loop where you try to access a site, your AV or firewall intercepts the request then spits back a valid IP or denies it if there are issues.
14-12-2014 10:53 AM
Try - http://176.31.229.107
14-12-2014 11:10 AM
Not Samknows.com as above, nor some others I have sought to try, but I can get to google.co.uk via http://74.125.230.247
Beating the heck out of me!
14-12-2014 11:39 AM
Do you use any networked proxy server ?
Does W8 have a "Repair Connection" button (like Win-XP had), if so might be worth trying ?
14-12-2014 11:47 AM
Proxy No
"Fix the connection" simply concludes that the remote device / resource is not responding.
This is starting to look like I need to get WireShark installed
14-12-2014 12:05 PM
Quote from: DomS Have you tried manually setting your DNS servers as 8.8.8.8 on your local PC ?
Dom,
How darned strange - this appears to "avoid" the issue***, so I now need to understand what is happening and why.
Having changed the DNS to 8.8.8.8 I get the nslookup serviced correctly as before, but now ping URL resolves to the correct address. It is nearly as though nslookup and ping / tracert / browser are using a different resources to resolve the address.
TG582n (firmware 10.2.2.B) has been xDSL connected for 152 days, PPP for 82 days - might this be a memory (leak) issue?
Multiple other devices in the house hold are all working fine (Win7 / Vista / iPhones / iPads / iPlayer on PVR) - only yhe Win8.1 platform is playing up. Any right now I can go and get the AV / Firewall updated.
Any suggestions on how to determine what is happening here will be most welcome.
Thank you to all who have contributed thus far.
Kevin
***Edit: Just thought (having put this back to default settings and it remains fixed) there is every chance that the initial configuration change rebooted the IP stack which is the actual fix here. That said the PC has had a couple of restarts over the last 48 hours whilst I have been looking at the problem.
14-12-2014 12:19 PM
14-12-2014 12:39 PM
Though next time I'll do a "ipconfig /displaydns"first to see if it gives any clues.
I rather thought I knew my way around this space - this is the strangest issue I've had in a long while. I have seen these "odd" resolutions before, however they were consistent for nslookup and ping etc.
Cheers,
Kevin
