172 IP address applied after a reboot tonight - 15th May
- 172 IP address applied after a reboot tonight - 15...
15-05-2014 5:40 PM
Just did a reboot to see if DLM has caught up yet or if my SNR ticket had been actioned and was given the Ip address 172.16.62.198 , second reboot cleared it.
FTTP 500 regrade from Tues 28th November
Message 1 of 3
(608 Views)
2 REPLIES 2
Re: 172 IP address applied after a reboot tonight - 15th May
16-05-2014 3:10 PM
Hi Gus,
It's not showing that your IP changed from it's static one, were you able to browse OK?
Message 2 of 3
(348 Views)
16-05-2014 3:21 PM
Then no not while I had the 172 IP, that was the reason I checked my router log for the IP address I got.
Message 3 of 3
(348 Views)
