13mb downloads and still buffering issues on catch up services
daro2096
As subject line. Getting sick of having buffering whilst watching programmes on BBC iPlayer
daro2096
Re: 13mb downloads and still buffering issues on catch up services
Done a broadband speed check and it is actually about 7Mb. It is supposed to be about 13, 14Mb.
To be frank when I was living at my last address I was getting better service at just 3.4Mb. How high does the Mb have to be to avoid buffering issues?
Fixes: 64
13mb should be more than enough to stream without experiencing the type of problems you've mentioned.
Is the connection being used for anything else at all whilst you're trying to stream?
Also are you connecting over WiFi whilst doing this?
 Adam Walker
daro2096
I was watching HD content. Whether it is wired or wireless shouldn't make any difference. It is back to normal speed expected for the area.
PeeGee
Quote from: daro2096
Except that wired can maintain the nominal thoughput in each direction (assuming duplex links) whereas wireless is very much dependent on how much of the nominal throughput is actually usable. The latter is affected by the volume of data going in each direction, number and type of connections at your access point (AP) and the number of external links to other APs which cause degradation of your signal/data.
If it's only you using the connection, the AP is set for a single standard (802 11n or 11g) and there are no other interfering devices, plus you have a favourable (solar) wind Roll eyes, you may get a little over half the maximum rate for the standard used Shocked . But you probably know that already Smiley
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
daro2096
Well I would used wired but I don't have a cable long enough currently.
