12:30am and I'm still capped to 512kbps???
- 12:30am and I'm still capped to 512kbps???
16-03-2009 12:30 AM
It's after midnight - I should be uncapped now!
What's up? I've got stuff to download...
Re: 12:30am and I'm still capped to 512kbps???
16-03-2009 12:47 AM
have you gone over your usage limit
best thing to try is disconnet internet and reconnect to get on a diffrent gateway and see if that resolves the issue. to check which gateway your on now and after use this http://usertools.plus.net/@gateway/
16-03-2009 12:50 AM
I'll try a disconnect and see what happens...
16-03-2009 12:52 AM
edit. looks like it stuck at 512k odd. iam on pcl-ag01 and going to try another gateway as well.
16-03-2009 12:57 AM
Torrents are now going quick, about 300kBps (that's Bytes, not bits)
But... usenet is still definitely stuck exactly at the capped 512kbps rate.
I get a full speed connection by the way; I'm about 400m from the exchange
16-03-2009 1:02 AM
did you check which gateway you where on before?
there was some odd goings on with pcl-ag03 the other day http://community.plus.net/forum/index.php/topic,74894.0.html
wonder if the the gremilins returned to the pcl family of gateways.
16-03-2009 1:04 AM
It's just turned 1:00am and my usenet download instantly jumped up to where it should be.
The clocks haven't gone back or anything have they? Or forwards - I never could remember...
Edit: Just checked - clock thing is next weekend.
Asbo Dog - thanks for the help. Looks like things are back to good, but there was clearly a glitch there somewhere.
I'll have to check this tomorrow night as well now, just in case...
Cheers!
16-03-2009 1:10 AM
16-03-2009 1:11 AM
yep looks like gizmo got wet again
i jumped gateway in beetween 12 - 1 and got the higher p2p speed. so if the clocks are wrong they cant be a full hour out
edit looking at post times i got in there 5 mins b4 1am
16-03-2009 1:18 AM
Samuria - I noticed the link in your sig. I got used for a demo of a 1" (or so) punch from my Sensei once, and only once! Through a new, thick and hard strike pad held against me chest it felt like his fist hit between my lungs! It made full-force kicks from the other black belts feel like playful taps! I had even more respect for him after that...
16-03-2009 4:34 AM
16-03-2009 6:31 PM
I've had a repsonse to my ticket stating that this was due to the traffic shaping change 'filtering through' to me. I've never observed that before, instead it has previously been exactly at the specified times, especially the drop to a lower limit! Believe me, I notice these things (think obsessive/compulsive about time!)
The change to unlimited bandwidth happened at exactly 1:00am - surely not just a coincidence of a random 'filtering through' time
If the changes to unlimited can take an hour or more to take effect, then the service is faulty and unacceptable.
Sorry to be so straight, but that's just not acceptable.
I'm still of the opinion that it was a glitch in the system for some reason, not a 'filtering through' of the change. I really hope I'm correct.
16-03-2009 6:50 PM
So I've lost one full hour of unlimited access.
16-03-2009 7:40 PM
Thanks for letting us know, I've asked Comms and Networks to have a look for you. Seems to be an hour out, we'll find out why and let you know.
16-03-2009 10:57 PM
