(104) connection reset by peer
Blackheartuk
Hi guys, since yesterday I've had problems accessing a website. I get a read error which states '(104) connection reset by peer'. I've tried resetting my history and cookies and this doesn't work.
Can anyone please help? Thanks
Fixes: 20
Re: (104) connection reset by peer
Did it look like this:
The following error was encountered:
    Read Error
The system returned:
    (104) Connection reset by peer
An error condition occurred while reading data from the network. Please retry your request.
Generated Sat, 28 Nov 2015 07:54:18 GMT by pcl-iwfcache03.plus.net (squid)
I was on 195.166.130.205 (ptw-bng02?) when I got the above message.
You could try logging into your router, clicking disconnect, then clicking connect a few seconds later, to connect to a different Plusnet gateway. Or wait for Plusnet to sort out their IWF cache, which might not get looked at until Monday, if that's even where the problem is.
Blackheartuk
That's exactly it!
I don't mean to sound stupid but how do log into my router? I don't have a PC or a laptop. I just use my Iphone.
Thanks!
Lisa
Fixes: 20
If it's one of the Plusnet routers, go to:
http://192.168.1.254
The login username and password are usually on the label on the back or bottom of the router.
Blackheartuk
Thanks, I'll give it a go.
Thanks so much for all your help!
MrK
Its been like this for around a week now. It loaded fine for me via a proxy site however.
Im on gateway pcl-bng04. fwiw
Blackheartuk
Hi I tried resetting my router but sadly this didn't work
MrK
Yeah its not your end - its at ISP end for sure. Youll just have to wait it out or kick up a fuss if it goes on much longer as theres no good reason for it being blocked. Meanwhile you can use this - https://www.proxfree.com/
vanhelsing
Got the same problem. I turned off safeguard which theoretically should have worked but didn't. Reset the router, flushed the DNS but nothing has worked. Don't want to use a proxy for browsing. Plusnet sort it out.
Anyone want to suggest anything else can be done?
VH
Fixes: 96
If you're talking about the website I think you are, then we're aware and engineers are looking into it.
galahad1980
Grin, haha If you talking about the website I think we all know we're talking about then everyone here is depraved.
Fixes: 96
Pushing for a fix this week, might not be until towards the end of the week though I'm afraid.
Fixes: 20
Well, at least it could be amusing if this makes The Register.
Blackheartuk
Haha fab  Cheesy
