100+ connection losses is this even normal?
- Re: 100+ connection losses is this even normal?
07-07-2015 9:20 PM
So recently Open reach engineer visited to fix line speeds which have somewhat been resolved but with the now constant connection losses, speeds are not consistant (even though 60% of the time it hits top speeds) if you look below at the stats you can see I'm averaging 3-5 connection losses everyday. This is ridiculous because I can't get a constant strong connection giving me constant top speeds. I came onto the forum before but didn't get any response from staff. I think the connection losses is the final thing to resolve regarding my whole broadband drama. Like I already mentioned, we've already fixed speeds and I now (if the connection isn't lost) get good speeds but with constant connection drops its still a nightmare.
Link Information
Uptime: 0 days, 0:50:47
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,151 / 9,579
Data Transferred (Sent/Received) [GB/GB]: 11.90 / 265.90
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 22.4 / 39.5
SN Margin (Up/Down) [dB]: 5.7 / 5.6
Loss of Framing (Local/Remote): 954 / 0
Loss of Signal (Local/Remote): 108 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 58,735 / 114
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 6 / 33,052
HEC Errors (Up/Down): 9 / 16,778
Link Information
Message 1 of 5
(1,068 Views)
4 REPLIES 4
07-07-2015 10:07 PM
Is there some reason you have a 4 yea rold ping test result in your signature? A quick glance at that suggests your line is ok.
Have you tried going back to your old router?
Message 2 of 5
(770 Views)
08-07-2015 10:35 PM
Was meaning to get rid of that signature I've removed it now, with regards to router it isn't a router problem rather a wiring issue I think I've had connection losses even with the older router hence why i asked for a new one because I thought it may have been a router issue at first but that's now out of the question.
Message 3 of 5
(770 Views)
08-07-2015 11:22 PM
OK - tried two routers - current one now in the master socket? when you lose the connection
are there red lights on your router?.
Are the drop outs at the same time/times each day - does this coincide with anything happening in
your flat. Switching on a big TV or a shower - something that takes a lot of current.
Do the dropouts coincide with incoming landline calls
Suggest you read up a bit on REIN and think if it might apply
Message 4 of 5
(770 Views)
09-07-2015 9:44 AM
Our RADIUS logs aren't showing anywhere near that number of disconnections however that is something that can occasionally happen if the disconnections are very very brief.
I've just been through a line test and the errors on the line don't look great, with an error roughly every 2 seconds.
Is there any noise on the phone line at all? Plug a single corded handset in to the test socket and dial 17070 following the instructions for the quiet line test.
Message 5 of 5
(770 Views)
