10% of typical broadband speed for the last 24 hours
cerzi
I've tried texting HELP to the support number but no response (what happened to web chat?). Not sure if it's our router or if there is a problem elsewhere - pinging the router locally over Ethernet gives higher and less stable ping than normal, but not enough to justify having about 3mbit download. Would great appreciate if this could be investigated. Thanks a lot!
6 REPLIES 6
Fixes: 345
Re: 10% of typical broadband speed for the last 24 hours
@cerzi If you have tried the BOT but received no response (strange), try following the script below.
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub (with the 'Username' obscured) would be a good starting point.
For the Hub One -
For the Hub Two -
csmith94
Fixes: 31
Hi @cerzi, thanks for getting in touch. I'm sorry no one has been back in touch with you, although it doesn't look like the text service has registered on the account as I can't see an automated line test.
However, I've ran a test on your line and found a high resistance fault, Openreach wish to send an engineer to your premises to further investigate this.
Openreach operate 2 timeslots for visits. These are AM ( 0800-1300) and PM (1300-1800), Monday to Friday
Please provide 3 timeslots you could attend and we will book the appointment for you and contact you to confirm when the engineer will be visiting.
Please note if an engineer visits your premises and is unable to gain access or if the fault is found to be caused by your equipment, your set up or your phone socket, the engineers may refer you back to us to discuss the next steps.
 Curtis Smith
cerzi
Hello, great thank you it's good to know there's a clear issue. Will be able to do any time monday or Tuesday, or in the afternoon on Wednesday.
Thanks again
csmith94
Fixes: 31
Thanks for letting me know, I've got an appointment booked in for the 11/04/23 between 8AM and 1PM. The Engineer will attempt to resolve the fault externally first before coming round, they will keep in touch on the day of the appointment.
Once the Engineer has been, our Faults Team will follow up to make sure everything is ok or if anything else needs to be done.
In the meantime, is there anything else you need from me today?
- Curtis, Plusnet Sheffield
 Curtis Smith
cerzi
Perfect thank you!
csmith94
Fixes: 31
No worries at all Smiley
Enjoy your Easter bank holiday!
 Curtis Smith
