10.30pm and still laggy
bullethead
from 6.00pm and up to 10.30pm nothing but lag
if I lagged anymore I would find myself in Narnia while playing BF4
Fixes: 162
Re: 10.30pm and still laggy
Testing your line isn't showing any issues at all, can you advise how you're connecting? Is this wired or wireless? Do you have any problems with other online services or just gaming?
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0003
Description No problem found, OAM test is not currently supported on this line.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 66.9 Mbps
Upstream Speed 20.0 Mbps
 Chris Parr
 Plusnet Staff
bullethead
its all good Im using the "phone" options to sort this so far a static IP is the next step
