10.2.2.9 Firmware
apjashley1
10.2.2.9 Firmware
Is anyone else running 10.2.2.9 on their 582n?
It has an essential feature for me (time-based access control) as well as IPv6 support.
I'm noticing disconnects every 3-4 hours, which isn't an issue other than it's making my line look unstable and reducing my sync speeds...
prichardson
Re: 10.2.2.9 Firmware
Can you advise what type of disconnects you are seeing?
Is both the broadband and internet lights going out, or just the internet?
apjashley1
Quote from: P
I'm not sure, the router is tucked away - websites don't load for approx 30s, and the router page will say "your DSL connection is down". It quickly comes back up and the sync rate is usually lower.
