JamesM
1
Smiley
1 REPLY
matt_2k34
Re: PPP fail : Peer terminate
Starting at midnight - PPP drop was probably caused by BT doing some work in the exchange - some routers dont gracefully handle it and may report a bad response, even when it isnt properly trying.
That or the PN gateway you were trying to connect to was having a fit - but they're load balanced in a round robin format i believe - so you wouldnt get the same gateway for multiple attempts.
But i would go more with the maintenance... Smiley
Regards
