JamesM
1
Smiley
jojopillo
Re: 21CN WBC
Hi James,
Indeed, that's exactly what it means. Although, if you're getting less that 4000k sync at the moment then you may not see that much benefit.
Jojo Smiley
rongtw
Fixes: 12
Re: 21CN WBC
well i am still living in hope my exchange still says "The estimated go live date is between 1st March 2011 and 31st March 2011."  Huh
and last updated 7/1/2011 still no more info
Re: 21CN WBC
Check your exchange using this site http://www.dslchecker.bt.com/adsl/adslchecker.welcome - it seems to give the most up to date information.
On the PlusNet exchange checker, my exchange also has an ADSL2+ date of 31 March but on the BT site it has been put back to the end of May.
Bob
rongtw
Fixes: 12
Re: 21CN WBC
cheers, bobboulby , but even that says it should be live about 31/3/2011.
but no updated info  Embarrassed
JamesM
Re: 21CN WBC
Smiley
jojopillo
Re: 21CN WBC
Yes, it can be called that. With 7616k you should see quite an improvement in your speed if you go on to 21CN Smiley
JamesM
Re: 21CN WBC
Smiley
Fixes: 46
Re: 21CN WBC
I suggest checking that the BT Availability Checker mentioned in Reply #3 confirms today's date. If it does submit a ticket requesting immediate migration as mentioned in the quoted paragraph from this blog. That worked for me.
[quote=http://community.plus.net/faster-plusnet-broadband-for-free-faq/]
Can I opt-in earlier if I want to?
Yes, please raise a ticket via the help assistant on our website asking to be moved to the faster speeds. We’ll then place this order at the earliest opportunity
David
Tomplus73
Re: 21CN WBC
Quote from: bobboulby
Bob
Thnks for link,have just checked for my location and see I'm due to get uprated on or about July 1st.
Be interesting to see what difference it makes................ Smiley
JamesM
Re: 21CN WBC
Smiley
itsme
Re: 21CN WBC
Your line will not be upgraded. When the exchange is enable for ADSL2+ it mean that it has the equipment. For a line to be upgraded it has to be physical connected to this equipment which require rejumpering on the MDF. This is not done automatically PN has to request it.
Fixes: 46
Re: 21CN WBC
@JamesM
The wording is probably "… your line currently supports an estimated ADSL2+ broadband line speed of …" but it does mean you can be moved to the ADSL2+ service if you raise a ticket. Smiley
David
JamesM
Re: 21CN WBC
Smiley
JamesM
Re: 21CN WBC
Smiley
