1
10-01-2011 11:29 PM
Re: Attenuation dB
10-01-2011 11:45 PM
Re: Attenuation dB
10-01-2011 11:52 PM
Re: Attenuation dB
11-01-2011 12:55 AM
You would think that they could get the basics right but they often don't.
You could try checking whether there is a firmware upgrade available, that sometimes corrects errors (and sometimes introduces new ones).
Re: Attenuation dB
11-01-2011 8:10 AM
Re: Attenuation dB
11-01-2011 9:42 AM
Quote from: walker23 You would think that they could get the basics right but they often don't.
You expect a lot from a device which is a fraction of the price of decent measuring equipment that would return accurate figures.
Re: Attenuation dB
11-01-2011 12:57 PM
My router, a DG834GT had a known problem where the noise margin and attenuation figures were swapped, which got sorted with a firmware upgrade. Not sure that's your problem though...
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: Attenuation dB
11-01-2011 1:21 PM
Re: Attenuation dB
11-01-2011 1:25 PM
Just ran a line test and your attenuation is 29dB Downstream and 17dB upstream.
Jojo
Re: Attenuation dB
11-01-2011 1:29 PM
Re: Attenuation dB
11-01-2011 1:44 PM
Re: Attenuation dB
11-01-2011 1:46 PM
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
