0.79 down speed
- 0.79 down speed
Re: 0.79 down speed
31-10-2014 2:48 PM
Cheers
Re: 0.79 down speed
31-10-2014 5:41 PM
Post a link of one you think is OK.
Re: 0.79 down speed
01-11-2014 6:54 AM
Re: 0.79 down speed
01-11-2014 8:31 AM
When connecting the extension, you only use the Blue pair and no other wires. You connect to the rear of the removable faceplate. The Blue + white trace goes on Terminal 2 and the White + blue trace goes on terminal 5. You don't strip the wires, the terminals are IDC "Insulation Displacement Connectors". You push the wire into the terminal using the tool provided - do not use a screwdriver or other implement in the terminal as this can open the jaws of the terminal and give a bad connection.
Re: 0.79 down speed
01-11-2014 1:24 PM
ill install all this later on this evening and give you an update. Cheers
Re: 0.79 down speed
01-11-2014 2:11 PM
Whenever you do it, post up the DSL stats when connected and we'll see what they are looking like.
Re: 0.79 down speed
02-11-2014 11:19 AM
Tested the secondary line and the phone works but not the Internet side of things. I have connected as specified one side of the cable to the master socket faceplate and the other side is attached the secondary socket faceplate. Although from the front of the secondary socket it is just a telephone socket unlike the master socket which has a telephone and adsl sockets.
I'm missing something of course just not entirely sure what
Re: 0.79 down speed
02-11-2014 11:22 AM
Re: 0.79 down speed
02-11-2014 11:42 AM
I've just been reading through all this and have a couple of questions for you.
Can you see your master socket on the following link?
http://www.plus.net/support/broadband/master-socket-guide.shtml
If so which socketed is it?
If its not listed can you provide a picture of your socket and how you have it wired in?
In one of your earlier posts you mention that both your line and you friends run from a small black box. Prior to that black box is it the same phone line to the telegraph poll?
If thats the case that may well be the problem as essentially you would be sharing the same cable running back from that black splitter box to the local cabinet this is known as starwiring.
Re: 0.79 down speed
02-11-2014 12:02 PM
Quote from: alliasjay As soon as i plus the old cable back into the master socket the line status says 'showtime' hmm
Well that surely means it has synced - any stats?
@PeterBirt
It is two separate lines sharing the same drop-wire, there is no star wiring involved - please don't confuse the issue.
As for the NTE5A - latest type see reply #13.
Re: 0.79 down speed
02-11-2014 12:04 PM
It is the same phone line that runs to the telephone pole yes. So one line coming to the house and then splits off into two separate lines.
Re: 0.79 down speed
02-11-2014 12:06 PM
It's only when I plug the old 30 meter flat cable that runs from the master socket to my computer upstairs when the internet is working. With the secondary extension line that I have put in I get use of the Phone but not anything on the internet as the modem just shows a status of Line Down.
Re: 0.79 down speed
02-11-2014 12:07 PM
Re: 0.79 down speed
02-11-2014 12:11 PM
You said you had a standard NTE5A in reply #13.
Re: 0.79 down speed
02-11-2014 12:13 PM
