0.0Mbps on Uplink - Anyone had similar issues?
old_fogey
For the last 2 days my broadband seemed almost unusable.  My router said I was connected OK, but nothing seemed to work reliably.  I finally managed to do a speed test earlier today (the one at speedtest.btwholesale.com doesn't complete if there is no significant upload speed), and got the following results from the which.co.uk speed test.
Date of test: ‎20‎/‎08‎/‎2018 ‎15‎:‎46‎:‎20
Response Time: 507ms
Download Speed: 2.1Mbps
Upload Speed: 0.0Mbps
I also tried 'pinging' the plus.net DNS server and was getting around 15% packet loss although the round trip time was 24mS which is much better than the which speed test.  My router indicated 1Mbps sync speed, 28.5dB line attenuation and 11dB SNR margin on the uplink so the line seems OK.
I raised it with plus.net as a fault earlier today, but wondered if anyone else has had similar issues?  It just feels like someone is hogging all the uplink bandwidth leaving none for me  :-(.  I know the download speed is low as well, but that is normal for here, after all we're out in the sticks 15 miles outside the M25.....
Andy
2 REPLIES 2
Fixes: 365
Re: 0.0Mbps on Uplink - Anyone had similar issues?
You may well have a fault. There is however an alternative reason Assuming that you have a Plusnet Hub Zero router you need to check whether you have got a heavy download task such as a Windows update in progress. The Hub Zero suffers from buffer bloat which throttles upload speed under heavy download conditions.
Fixes: 1,547
Sorry to hear you're experiencing speed problems Andy.
Our tests are showing HEC errors on the upstream which is usually indicative of a router fault.
Do you have another router you can try?
