why has a number been barred?
Rigga
Hi
I am trying to call a UK landline number, and it says that the number is barred.
I do not have any Call Barring rules setup so can only assume it's some sort of global bar?!?!?!
the number starts 01753 - i do not want to put the rest of the number in here.
And advice appreciated.
R.
Fixes: 57
Re: why has a number been barred?
Probably incoming calls are barred by the owner of the number - I wasn't aware that you could selectively bar VOIP calls
Rigga
I get a message saying call barred please contact your provider.
I can call this number fine from my landline, so I don't think it's the receivers end that's causing the problem.
I also get a line under recently barred calls on the PN voip web panel,
2012-01-27 12:20:22 Extension 65XXXXX 020XXXXXXXX 441753XXXXXX bar
2012-01-27 12:18:51 Extension 65XXXXX 020XXXXXXXX 441753XXXXXX bar
So it's definitely PN that's blocking the call.
Any comment from any member of PN staff?Huh
R.
Fixes: 57
As Plusnet use Gradwell I believe this may be relevant http://www.gradwell.com/support/kb/article.php?id=252
Fixes: 44
I was just going to post that link JIm but you beat me to it.
@rigga, Can you call any UK landlines ? if not then check that the PSTN access box is checked for the extension ( its in the guide in the link )
Rigga
Thanks for the suggestions, but I can call other UK landline numbers fine.
ans as I said previously I have no call barring rules setup.
Thanks for the help so far, anyone any other sugggestions.
R.
Fixes: 8
I think the next step will be for another PN VoIP user to try dialling the same number. Perhaps you could send one of us the number by PM (having warned the destination to expect a test call).
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Rigga
That's probably a good idea, however I would like a PN member of staff to look into it, If they want the number I can provide it.
Thanks for the suggestion.
R.
Fixes: 44
You're probably best raising a 'ticket' to get PlusNet to look into it.
Rigga
Ok will do that. Cheers.
R.
Rigga
I wonder if they could possibly make it a little more difficult to raise a support ticket on the PN web site. It's ridiculous. R.
James
I'm sure we could if we wanted to Wink
I'm sorry you found it a bit difficult - We have several different "workflows" within the call centre and it's important that your ticket reaches the right person first time, otherwise you would have to wait longer whilst it was passed to the right team.
Fixes: 57
Quote from: Rigga
They did - you should have tried the old system the number of times you finished up going around in circles  Crazy
itsme
Are you releasing the VoIP number?
Rigga
The number I called to get the bar? no not really..
It seems to be working now, which is good, and i've raised a support q. to find out what happened, as I really do not want it to happen again.
Thanks. R.
