speedtouch 716v5 problems connecting to voip
thistlec
i get a consistent  x  in the 'registered' column in the telephony panel on this modem.   the settings i am using are:
in configure menu:
SIP URI:   allocated phone number by plusnet....   nnnn-nnnnnn
Username:   'your sip id'  as notified by plusnet
Password:   'your sip password' as notified by plusnet
Confirm Password:   as above
Displayname:     Andy Thompson
Abbreviated number:   nnnn
Port:  Phone 1 Phone 2 All
Phone 1                 "with phone plugged in."  !
Expert Configure:
Registrar:       sip.plus.net
Registrar port      5060
Proxy        nat.plus.net
Proxy Port     5082
Expire Time   3600
i'm sure i've missed something obvious, but i'm going round in circles!    any help gratefully recieved !!
Fixes: 41
Re: speedtouch 716v5 problems connecting to voip
Your SIP ID doesnt start with a '4' does it ?
Try dropping the 4 and just using the last six digits.
RichSmol
nope - your extension doesnt start with a 4 - try entering your extension number in the SIP URI
thistlec
still getting no voip....!
SIP URI:   nnnnnn
Username:   nnnnnn
Password:   as notified by plusnet
Confirm Password:
Displayname:   """""""""
Abbreviated number:
Port:  Phone 1 Phone 2 All    all
have tried both  sip id  and the  allocated phone number nnnnnnnnnnn   in the sip uri with no joy at all !
thistlec
I would edit your post to remove the personal details from your settings. This is a public forum after all!
Fixes: 41
I did read somewhere on the forums about a problem with the latest firmware for the 716v5 but cant seem to find it now...
Maybe you could have a look as I'm off home now. Will check in later this evening to see how things are going , also maybe Puddy might spot this thread cos I'm sure he's got a 716 working.
RichSmol
thistlec - just to confirm, i've been able to register your account and make an outbound test call through SJPhone so the account is up and running.
thistlec
ok   thanks to all i now have it all up and running....
settings   now working are:
Configure Menu
sip uri  "your sip id"  as notified by plusnet
username                        "your user name" as notified by plusnet
password      "password" as notified by plusnet
displayname    plusnet
abb num    nnnnn.nnnnn        i use my allocated phone number i chose from plusnet
port  all
Expert Configuration
Service Configuration
registrar  sip.plus.net
registrar port   5060
proxy       nat.plus.net
proxy port        5082
Fixes: 41
So, for future reference , what was the problem ?
puddy
Correct setting 8 Nov 2008
Just to confirm settings below for a speedtouch 716v5 wireless router
Points to note the last firmware update can lock both voip ports up and you may have to re-flash with an older firmware
you can backup the settings for the router should any problems come up
Home >toolbox>telephony
Config
Telephony Identity
SIP URI:   extension number abbr number
Username: As above
Password:   Huh?
Confirm Password:  Huh?
Displayname:   Anything
Abbreviated number:Anything/blank
Port: 1 or 2 or all
Expert config page
Registrar Port:  5060
Proxy:   natproxy.plus.net
Proxy Port:   5082
Expire Time:  3600
remember to put the tick in the telephony  box when finished
The router may have a delay period before the voip light comes on so go make a cup of tea
puddy
Best bit of all I liked the most  about my speedtouch 716wlv 5 router was its 99p price plus p&p total cost less than £6 with a 90 day warranty
thistlec
hi ian....  where i went wrong originally was with the sip URI    since this was my first venture into VOIP  i got confused with the different naming conventions between what the modem wanted and the settings notified by plusnet!   hopefully  the panel on my last post with the sucessful settings is clear as  i have used the names as notified by plusnet.       I also lioved the super low price from digidave !
puddy
hi thislec
We are always here to help.  we all started from the same place you did, glad you found digidave I have had quite a few routers from him to and not one problem came up. I just wish all ebay seller were as good as him.
puddy
