samsung i8510 SIP
tangey
samsung i8510 SIP
Hi, I've recently purchased one of these.  The interface is S60 and so it appears just like an N95.  I have used the settings found on here for the N95, and indeed the phone confirms that it is registered with the SIP provider.
My problem is after that, how do I actually make a phone call.  Been ages since I used the SIP function of my N95, but as far as I recall, when it was registered, you got "internet call" as an option in addtion to the voice call and video call options.  But on this phone I don't see any internet call as an option in the dialing application.
I know its a long shot, given how new this phone is, but I thought I'd give it a shot.
Regards
Ian
Fixes: 44
Re: samsung i8510 SIP
This
In terms of preloaded applications, the Samsung i8510 is the most fully-featured we've seen. Just wander into the applications menu and you'll see Fring for making VoIP calls and keeping in contact via IM
seems to imply that it comes preloaded with Fring.
That ought to allow you to make voip calls
tangey
Decided to give Fring a go and yes it works fine on the samsung.
Now if only I could get the pure SIP stuff gonig rather than via Fring....
Fixes: 44
I couldnt find anything about any other SIP client on that phone yet...
Glad you got Fring to work though.
