plustalk and tribox CE
sianddan
Hey all,
I've just signed up with plusnet and activated my plustalk account and, being a telephone engineer, figured I'd have a bash at getting trixbox set up so that my housemate and I could share the SIP line we now have.
I have a hunch I have misconfigured my trixbox trunk though, because I don't receive incoming calls to Asterisk, and I can't make outgoing calls because there are no trunks available. Anyone have any ideas what I'm missing? I've posted a copy of the debug output from Asterisk when I dial from my PC - I've replaced the outbound CLI, dialled number and my SIP account number with "mylandline", "mymobile", and "myacct" respectively.
   -- Registered SIP '201' at 192.168.1.5 port 23242 expires 3600
    -- Executing [9mymobile@from-internal:1] Macro("SIP/201-08574c38", "user-callerid|SKIPTTL|") in new stack
    -- Executing [s@macro-user-callerid:1] NoOp("SIP/201-08574c38", "user-callerid: device 201") in new stack
    -- Executing [s@macro-user-callerid:2] Set("SIP/201-08574c38", "AMPUSER=201") in new stack
    -- Executing [s@macro-user-callerid:3] GotoIf("SIP/201-08574c38", "0?report") in new stack
    -- Executing [s@macro-user-callerid:4] ExecIf("SIP/201-08574c38", "1|Set|REALCALLERIDNUM=201") in new stack
    -- Executing [s@macro-user-callerid:5] NoOp("SIP/201-08574c38", "REALCALLERIDNUM is 201") in new stack
    -- Executing [s@macro-user-callerid:6] Set("SIP/201-08574c38", "AMPUSER=201") in new stack
    -- Executing [s@macro-user-callerid:7] Set("SIP/201-08574c38", "AMPUSERCIDNAME=Daniel Arkley") in new stack
    -- Executing [s@macro-user-callerid:8] GotoIf("SIP/201-08574c38", "0?report") in new stack
    -- Executing [s@macro-user-callerid:9] Set("SIP/201-08574c38", "AMPUSERCID=201") in new stack
    -- Executing [s@macro-user-callerid:10] Set("SIP/201-08574c38", "CALLERID(all)="Daniel Arkley" <201>") in new stack
    -- Executing [s@macro-user-callerid:11] Set("SIP/201-08574c38", "REALCALLERIDNUM=201") in new stack
    -- Executing [s@macro-user-callerid:12] ExecIf("SIP/201-08574c38", "0|Set|CHANNEL(language)=") in new stack
    -- Executing [s@macro-user-callerid:13] NoOp("SIP/201-08574c38", "TTL:  ARG1: SKIPTTL") in new stack
    -- Executing [s@macro-user-callerid:14] GotoIf("SIP/201-08574c38", "1?continue") in new stack
    -- Goto (macro-user-callerid,s,23)
    -- Executing [s@macro-user-callerid:23] NoOp("SIP/201-08574c38", "Using CallerID "Daniel Arkley" <201>") in new stack
    -- Executing [9mymobile@from-internal:2] Set("SIP/201-08574c38", "_NODEST=") in new stack
    -- Executing [9mymobile@from-internal:3] Macro("SIP/201-08574c38", "record-enable|201|OUT|") in new stack
    -- Executing [s@macro-record-enable:1] GotoIf("SIP/201-08574c38", "0?2:4") in new stack
    -- Goto (macro-record-enable,s,4)
    -- Executing [s@macro-record-enable:4] AGI("SIP/201-08574c38", "recordingcheck|20080729-211730|1217362650.43") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/recordingcheck
  recordingcheck|20080729-211730|1217362650.43: Outbound recording not enabled
    -- AGI Script recordingcheck completed, returning 0
    -- Executing [s@macro-record-enable:5] NoOp("SIP/201-08574c38", "No recording needed") in new stack
    -- Executing [9mymobile@from-internal:4] Macro("SIP/201-08574c38", "dialout-trunk|2|mymobile||") in new stack
    -- Executing [s@macro-dialout-trunk:1] Set("SIP/201-08574c38", "DIAL_TRUNK=2") in new stack
    -- Executing [s@macro-dialout-trunk:2] ExecIf("SIP/201-08574c38", "0|Authenticate|") in new stack
    -- Executing [s@macro-dialout-trunk:3] GotoIf("SIP/201-08574c38", "0?disabletrunk|1") in new stack
    -- Executing [s@macro-dialout-trunk:4] Set("SIP/201-08574c38", "DIAL_NUMBER=mymobile") in new stack
    -- Executing [s@macro-dialout-trunk:5] Set("SIP/201-08574c38", "DIAL_TRUNK_OPTIONS=tr") in new stack
    -- Executing [s@macro-dialout-trunk:6] Set("SIP/201-08574c38", "GROUP()=OUT_2") in new stack
    -- Executing [s@macro-dialout-trunk:7] GotoIf("SIP/201-08574c38", "0?nomax") in new stack
    -- Executing [s@macro-dialout-trunk:8] GotoIf("SIP/201-08574c38", "0?chanfull") in new stack
    -- Executing [s@macro-dialout-trunk:9] GotoIf("SIP/201-08574c38", "0?skipoutcid") in new stack
    -- Executing [s@macro-dialout-trunk:10] Set("SIP/201-08574c38", "DIAL_TRUNK_OPTIONS=") in new stack
    -- Executing [s@macro-dialout-trunk:11] Macro("SIP/201-08574c38", "outbound-callerid|2") in new stack
    -- Executing [s@macro-outbound-callerid:1] GotoIf("SIP/201-08574c38", "1?start") in new stack
    -- Goto (macro-outbound-callerid,s,3)
    -- Executing [s@macro-outbound-callerid:3] NoOp("SIP/201-08574c38", "REALCALLERIDNUM is 201") in new stack
    -- Executing [s@macro-outbound-callerid:4] GotoIf("SIP/201-08574c38", "1?normcid") in new stack
    -- Goto (macro-outbound-callerid,s,9)
    -- Executing [s@macro-outbound-callerid:9] Set("SIP/201-08574c38", "USEROUTCID=") in new stack
    -- Executing [s@macro-outbound-callerid:10] Set("SIP/201-08574c38", "EMERGENCYCID=") in new stack
    -- Executing [s@macro-outbound-callerid:11] Set("SIP/201-08574c38", "TRUNKOUTCID=mylandline") in new stack
    -- Executing [s@macro-outbound-callerid:12] GotoIf("SIP/201-08574c38", "1?trunkcid") in new stack
    -- Goto (macro-outbound-callerid,s,16)
    -- Executing [s@macro-outbound-callerid:16] GotoIf("SIP/201-08574c38", "0?usercid") in new stack
    -- Executing [s@macro-outbound-callerid:17] Set("SIP/201-08574c38", "CALLERID(all)=mylandline") in new stack
    -- Executing [s@macro-outbound-callerid:18] GotoIf("SIP/201-08574c38", "1?report") in new stack
    -- Goto (macro-outbound-callerid,s,22)
    -- Executing [s@macro-outbound-callerid:22] NoOp("SIP/201-08574c38", "CallerID set to "" <mylandline>") in new stack
    -- Executing [s@macro-dialout-trunk:12] AGI("SIP/201-08574c38", "fixlocalprefix") in new stack
    -- Launched AGI Script /var/lib/asterisk/agi-bin/fixlocalprefix
  ==  fixlocalprefix: Dialpattern . matched. mymobile -> mymobile
    -- AGI Script fixlocalprefix completed, returning 0
    -- Executing [s@macro-dialout-trunk:13] Set("SIP/201-08574c38", "OUTNUM=mymobile") in new stack
    -- Executing [s@macro-dialout-trunk:14] Set("SIP/201-08574c38", "custom=SIP/plusnet") in new stack
    -- Executing [s@macro-dialout-trunk:15] GotoIf("SIP/201-08574c38", "1?gocall") in new stack
    -- Goto (macro-dialout-trunk,s,17)
    -- Executing [s@macro-dialout-trunk:17] Macro("SIP/201-08574c38", "dialout-trunk-predial-hook|") in new stack
    -- Executing [s@macro-dialout-trunk:18] GotoIf("SIP/201-08574c38", "0?bypass|1") in new stack
    -- Executing [s@macro-dialout-trunk:19] GotoIf("SIP/201-08574c38", "0?customtrunk") in new stack
    -- Executing [s@macro-dialout-trunk:20] Dial("SIP/201-08574c38", "SIP/plusnet/mymobile|300|") in new stack
    -- Called plusnet/mymobile
    -- SIP/plusnet-0852a458 is circuit-busy
  == Everyone is busy/congested at this time (1:0/1/0)
    -- Executing [s@macro-dialout-trunk:21] Goto("SIP/201-08574c38", "s-CONGESTION|1") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,1)
    -- Executing [s-CONGESTION@macro-dialout-trunk:1] GotoIf("SIP/201-08574c38", "1?noreport") in new stack
    -- Goto (macro-dialout-trunk,s-CONGESTION,3)
    -- Executing [s-CONGESTION@macro-dialout-trunk:3] NoOp("SIP/201-08574c38", "TRUNK Dial failed due to CONGESTION - failing through to other trunks") in new stack
    -- Executing [9mymobile@from-internal:5] Macro("SIP/201-08574c38", "dialout-trunk|2|mymobile||") in new stack
    -- SIP/plusnet-0852b9e8 is circuit-busy
    -- Executing [9mymobile@from-internal:6] Macro("SIP/201-08574c38", "outisbusy|") in new stack
    -- Executing [s@macro-outisbusy:1] Playback("SIP/201-08574c38", "all-circuits-busy-now|noanswer") in new stack
    -- <SIP/201-08574c38> Playing 'all-circuits-busy-now' (language 'en')
  == Spawn extension (macro-outisbusy, s, 1) exited non-zero on 'SIP/201-08574c38' in macro 'outisbusy'
I guess I should also mention that calls work both ways when I use SJPhone from my PC instead of connecting Asterisk, so I'm fairly sure it's not a firewalling issue.
Any help would be appreciated!
Best Regards
Daniel
pd
Re: plustalk and tribox CE
Daniel,
You'll find the settings I use for Asterisk here if they are of any use to you.
Peter
sianddan
Hi Peter,
They seem to do the job for outgoing calls. Just gotta set up my routing for inbound now! Thanks for your help.
Daniel
